Where to connect (probably the case LED on/off button) cable. MSI MAG Vampiric 011C case.
adrkv9152f02dc
By building this PC only one cable has remained unconnected. There is button by the front panel IO which fully works(HDD LED, ON status led, Power on, Reset, mic, headphones and all 3 USB ports work ), but just this one button doesn't . I don't know excactly where to connect it. Both manual and a video on youtube do not specify where should I connect it. I'd like to send and image, but because they are not allowed: It's a small white connector with a black and grey wire. There is no beeper and the are only 4 fans inside (2 on the GPU, 1 on the back of chassis and 1 CPU cooler). Since can't post images to this thread (too large files), here is the link to the images: Cable and one controller on the case.
Mobo: Asus TUF Gaming X570 Plus
crramire153302dd
I have the same problem. Case MSI MPG SEKIRA 100P and mobo MSI MEG X570 UNIFY. Looks like there is a LED connector but nothing happens when I press the button
