Which ports will send video and/or power?
I just got a Cubi NUC 1MG, and I'm a bit confused about my options for video output. Instead of going through the HDMI ports, the video can go out through the USB ports, but which ones? The manual says that the front I/O can drive a monitor, but the front has only USB type-A 3.2. My monitor has USB-C input as well as HDMI, and I would like show the NUC through the USB-C input. I tried picking one of the USB-C ports in the back, but I didn't get a signal.
Also, do I have to use the power brick that came with the NUC, or can I use a USB port to power the computer as well? Which port would that be?
its the Rear Ports that can do USB DP alt mode both of the USB-C (Thunderbolt 4) ports and the one closest to the power input on the Cubi is the one that can Accept upto 100W in to power it.
