Why FuzzyLogic 4 can\'t function with my new 645Max2 m/b with P4
9
9000volts
Guest
I buy a new M/b model 645E Max2-L with using P4 1.6G A, which can o/c to 2.3G by setting 16 x 144 FSB in bios.
But I install the Fuzzy Logic 4 in windows XP. It seems doesn't work. I change the FSB to other setting and press the APPLY button. The CPU clock rate only change color from white to red, but the digit don't change. What problem is it.
I phone the hotline in MSI Hongkong, they only tell me the Fuzzy Logic 4 have BUG. So poor with this answer for MSI company........
Can anyone have idea to overcome the Fuzzy Logic 4 don't work problem?
Thx
9000volts
hi
its allways been usless from what ive read
id like to point out this is an athalon forum
you would ave more chance of an answer in the right forum
most here are nforce users and its never been usable with our board
If you have updated your BIOS, did you remember to load one of the settings afterwards? If you didn't, that might be the problem.
I don't use Fuzzy myself, but can't you try using the BIOS settings instead?
(wonkanoby: I see this thread in "Intel P4 & Celeron P4 based board" - if you see it elsewhere the new forum must have got it wrong)
they moved it kind of makes you look silly after
the daft thing is in the other forum its there with a big moved sign but in here nothing
Fuzzy logic 4 is a piece of crap, you can't do nothing with that besides overclocking your bus speed, the voltage increase dosen't work, you can't see your memory, pci and agp bus speed with that. Hello MSI what do you want us to do with this piece of crap besides frying our memory, pci and agp cards. I am really disapointed about this board, 645E Max-C. Anyone know where I could get Fuzzy logic 3 who apparently has all these nice features, or a similar program who let me modify my voltage, PCI,AGP bus speed and memory speed.
Thanks
