why my msi laptop stop charging for 1 second and start again automatically
Is there any dust in the connector? Is the connector broken ? Did you try moving the plug a bit to see what happens ? Maybe the psu is dieing ?
1. Check your power supply (does it happen if you charge your phone from the same outlet?).
2. Check if the adapter is plugged in and the charging port is connected to the laptop.
If you've checked all of these, and it's confirmed that the adapter is the problem, you'll have to contact your local service center to see if you need to change the adapter.
No there is no dust in connector and not broken and i also tried to move the plug but nothing happens
is this issue comes under warrenty?
