bmh67wa
- Feb 13, 2018
Ever since the latest MSI Center update to 1.0.38.0 the Graphics Fan Tool feature set will install but it doesn't run. After reading the current release notes I saw that it now says that it needs a PCIe 4.0 motherboard to work. It worked just fine before this update with my B450 Tomahawk MAX, which only has PCIe 3.0, and my MSI Twin Frozr RTX 2060 graphics card. Why the change and is there a way to prevent MSI Center from updating from 1.0.36.0 to the current version without disabling all Windows Store updates because all of the feature sets work just fine with that version but the Windows Store keeps updating it and breaking it again. I had to uninstall and reinstall it a few times to get Mystic Light working again too. This "update" is a mess it seems. Why do I like the Graphics Fan Tool? Because I enable it before I clean the dust out of the inside of my PC. It helps to blow it out. I see no reason for this change.
