Wi‑Fi Card Compatibility Question for MSI Thin GF63 12VF‑883XFR
nkhouatra15aa02e5
Hello community,
I own a MSI Thin GF63 12VF-883XFR laptop which currently comes with an Intel Wi-Fi 6 AX201 wireless card.
I would like to upgrade the Wi-Fi card and I have a question regarding compatibility. Since the AX201 uses the CNVio2 interface, could you please confirm whether the M.2 Key-E slot in this laptop also supports standard PCIe Wi-Fi adapters, or if it is limited to CNVio2-only cards?
More specifically, I would like to know if upgrading to newer adapters such as Intel AX210 / AX211 / BE200 would be supported on this model.
Thank you in advance for your help.
Best regards,
Nayel
If you plan to upgrade to a Wi-Fi 7 network card, the antennas also need to be upgraded accordingly, as the original antennas do not support it.
