will a aio cooler fit my case
davidosema15c202f1
hi i have a
MAG Codex 5 10SC-262UK
im trying to find out if i can aio cool it if so what one to get. please someone help
Nichrome
Friday? Deploy to prod!
Hi
It appears you might be able to fit 120mm AIO on the rear of the case.
Maybe 120/240mm on the front but I base my judgement on available resources (which is not a lot).
badboy2k
can fit a 120mm or 140mm in the rear
240mm or 280mm in the roof as there is mounts for 2 fans up in the roof of the case
badboy2k
if its a standard one one it will be a tight fit but should be able to go there.
if you already have it measure between the top of the case and the top of the RAM and if there is over 50mm of space you can have a 25mm thick rad and its fans
