- Nov 20, 2003
Purpose of the MSI Wind U90/U100/U100+ Notebook Patch:
* Force OFF CPU's Hyper-Threading Technology
* Patch NVRAM to modify Turbo function to be engaged by default, and apply @24% OC [E.g get ready to be activated with Fn+LCTRL or Fn+F10]
* Fixed issue Bluetooth cannot be turned ON in DOS
* Fixed issue SMBIOS Type 2 data incorrect.
* Add ==> Assign new function for the secondary MS$ special Windows button .
* Split ==> Fn+F11 Enable/Disable WLAN only.
* Split ==> CTRL+Fn+F11 Enable/Disable Bluetooth only.
* Add ==> Fn+ LCTRL ==> Enable/Disable ECO/Turbo Modes {Secondary way more comfortable}
* Add ==> Fn+ LWin ==> Enable/Disable WebCam {Secondary way more comfortable}
* Add ==> Fn+ Space ==> Mute On/Off {Secondary way more comfortable}
* Add ==> Fn+ C ==> Launch Calculator
* Add ==> Fn+ "Menu Button"[right Windows key] ==> Launch default E-mail client{Outlook, Thunderbird etc.} and without Fn:
Launch IE/Firefox{or redirect to home page if browser is already open and active else launch another copy}
* Apply custom logo screen.
* Fixed issue FAN always run at least at 45% RPM in Turbo Mode, without the matter how low is the CPU temp.
/* The FAN is adjusted depend of CPU Temp and NOT because the Turbo mode is used,
so when the CPU is running at low temp {normally in idle}, the same temp as Normal Mode,
the FAN will turn off like its works in Normal Mode. */
* Optimizing FAN Performance when notebook is working in Turbo Mode.
- Add-ed custom trigger Level 0 at 20% FAN RPM, CPU FAN will stay off until CPU reach 40C temp.{Real temp}
- Modify Turbo profile for CPU FAN Temp table trigger level 0, from 52 to 20.[C]
- Modify Turbo profile for CPU FAN RPM table trigger level 0, from 45 to 0.[RPM,%]
- Modify Turbo profile for CPU FAN Temp table trigger level 1, from 58 to 50.[C]
- Modify Turbo profile for CPU FAN RPM table trigger level 1, from 45 to 50.[RPM,%]
* Fixed issue when AC Main Power is plugged, Brightness automatically goes to 100%
- Modify stage 9 of Brightness control, adjusted from 200 to 80.
- Arrange Brightness control stage 9 to match with stage 5
[50%, which is actually 40% of monitor brightness because they are not adjusted with proportional increment],
So when AC Main is plugged it will not make difference for mode 1[Normal Mode] when its running at battery{where stage 5 is default}
or AC Main Power.
If ECO Mode is used and AC Main is plugged it will increase with one brightness level only.
{Not bump to the max like its happen in official BIOS}
- Modify stage 8 of Brightness control, adjusted from 184 to 195.
* Fixed keyboard resource conflict.
- NumLock will not longer cause permanent Blue keys printing characters and render keyboard useless for regular tasks.
- Blue sign now are formed only by pressing 'Fn+ desired blue key". [NumLock must be On 1st]
- Fixed keys["7","8","9","0","U","I","O","P","J","K","L",";","M",".","/"] their blue values and NumLock function
Apppy for Normal and Turbo Modes:
* [0] [20] - [50] - [58] - [64] - [70] -- [2x76] - [93]
* [0] -OFF - [24] - [33] - [45] - [65] -[3x100]
* Build and add new feature, "Svet's HT Feature" [To manipulate Intel's HT, On/Off]
* Build and add new feature "Svet's Auto PowerUp", [Allow MSI Wind to auto power on at specified day and time[dd/hh/mm/ss]]
* Fixed issue GPU-Z can't detect VBIOS version
* Update Atom microcode revision from V212[06.10.2008] to V218[10.04.2009]{Svet's Prefix version, 8FB7C1BAh, flag 4h}
* Other minor changes
* Patch BIOS to allow Turbo Mode usage when the notebook is running on battery only
* Patch BIOS to support modes combination
* Patch BIOS to split and support custom activation
* Patch BIOS to support custom Power LED's lights.
[Blue, Orange, Yellow, Green, White, Purple]
* Patch BIOS to able to use the custom lights with and without Turbo, with and without AC power cord
Keyboard combination details:
- Fn + F10 ==> Turbo Mode On/Off
- Fn+ Alt|AltGR + LCtrl ==> ECO Mode On/Off
From default Blue mode:
- Fn+ LCtrl [release] + Fn + Shift + F10 [release] ==> Yellow Power Led [Mode Mix: Turbo battery ON + Turbo Mode ON, used on: AC or battery]
or:
Fn + Alt|AltGR +LCtrl[or F10] [release] + Fn + F10[or LCtrl][release]
or:
Fn + Shift[L|R] + F10[or LCtrl] [release] + Fn + F10[or LCtrl][release]
or:
Alt|AltGR + Fn + F10[or LCtrl] [release] + Fn + F10[or LCtrl][release]
or
Shift[L|R] + Fn + LCtrl[or F10] [release] + Fn + F10[or LCtrl][release]
Continue from Yellow Mode:
Shift[L|R] + Fn + LCtrl ==> Purple Power Led [Turbo battery OFF, Turbo Mode ON, used on: AC or battery]
Fn + LCtrl ==> White Power Led [Turbo battery ON, Turbo Mode OFF, used on: AC or battery]
Fn, LSHIFT, LCTRL - From those keys you can control to all old and new modes, power lights, on both Battery and AC
Abracadabra eXtreme is available on donation:
or AC Main Power.
or:
or:
or:
or
