wrshamblinj153002d6
- Jun 4, 2026
Hello. I purchased a MSI Mag B860 Tomahawk Wifi motherboard from Newegg a couple of weeks ago. I am using an Intel Core Ultra 9 285K CPU, an MSI MPG A1000GS PCIE5 PSU, a Samsung 4TB 9100 Pro with Heatsink, and two G.SKILL Trident Z5 RGB Series DDR5 RAM sticks (F5-7600J3646G16GX2-TZ5RK). The initial installation of the motherboard and Windows 11 Pro went smoothly with no problems. However, I was having some instability issues with the MSI drivers I was using, and decided I wanted to start off with a fresh install. I used Microsoft's Media Creation Tool to create a bootable USB drive for the installation and wiped the drive with the Secure Erase feature in the BIOS.
However, when I rebooted to use the USB drive, all that comes up is the BIOS screen. I tried another USB drive and got the same results. For some reason, the motherboard will not let me boot anything other than the original installation of Windows 11 Pro, which unfortunately is gone. I tried turning off Secure Boot in the BIOS and changing the boot order to the USB drive to be the default boot device. I got the same results. All that comes up now is the BIOS screen. Is there some security feature with this motherboard that will only allow you one installation of Windows 11 Pro? Thanks in advance.
