Wired keyboard (K322?), how do I change the LED patterns?
duece_159e02e3
I threw away whatever paper came with the keyboard. I assumed it would be intuitive or the info would be easy to find online. My model# says OS1-XXXX180-809 and it came with my MSI Aegis pc. That seems to come up as a K322 keyboard on google, but there isn't much info. This pc, keyboard and mouse came from Costco.
I've seen recommendations to enable win/fn key swap in BIOS, but I'm not seeing that option anywhere in my BIOS. Mine of course shows different options than shown in this link. I've installed Mystic Light in the MSI Center, but I'm pretty clueless as to what I'm doing in there. Changing things in Profile 1 and hitting apply is having no effect. There's an LED dropdown with the following options: SELECT ALL, JRGB1, JARGB_V2_1, JARGB_V2_2. Then there's an LED Style dropdown as well and I can adjust colors within that style. No changes have any effect any of my LED's, the fans, keyboard, or mouse. Anyone know what I'm doing wrong?
That K322 you mentioned looks like GK100, can you try if the hotkey works?
That does work, thank you. Would the features in the pdf be the only possible features for this particular keyboard, or should I be able to take advantage of Mystic Light?
