Tech-Support X470 not working with 5800x3D PLEASE HELP
Troubleshooting
ferryheath
Hello all,
I have tried 3 different BIOS firmwares to get the 5800X3D to work on my MSI Gaming Plus X470 V1.2.
I tried vAL, vAM9, vAMA. I currently have vAM9 on the MOBO. I cleared the CMOS by removing the battery for a min 10 min.
Nothing I do will get the 5800x3D to POST. I have an EZ Debug LED on (CPU LED) that stays on whenever I try to run the 5800X3D.
My current system has this:
cpu = 2700x 240 mm AIO cooler
GPU = 6700xt
MOBO = MSI gaming plus x470 (V1.2)
Ram = 32 GB
PS = 700 Watt
OS = Windows 10
Thank you
Heath
I apologize in advance if you already followed this procedure:
With the 2700X and cooler installed, boot to Click BIOS, run M-Flash with the latest BIOS, vAMA, then put in the 5800X3D and cooler.
If you still get the solid red CPU EZ Debug led, then I suspect CPU socket pin damage or incorrect cooler pressure..
edit: the pins are located on the 5800X3D itself not on the motherboard socket.
I have tried that version. I also tried vAM9 and vAL. The 2700x will boot after I have done the BIOS updates. Just not the 5800X3D
given: 1. the computer has run without problem with the 2700X and BIOS AM9, AMA.
2. You have cleared CMOS after the BIOS change.
3. You get solid red CPU EZ Debug led when installing the 5800X3D.
4. The motherboard CPU pads and the 5800X3D pins are perfect.
Then the 5800X3D should be tested in a different motherboard that is designed for it with a compatible BIOS.
a friend, a computer shop ...
I have checked all that and I still get a CPU EZ debug light.. What is the most stable BIOS version for my MSI gaming plus X470 (V1.2) that will handle the 5800X3D???
I understand that you have done the four points I listed. That is why I wrote "given", meaning "take this as fact".
Given that your CPU chip fails the most basic POST check with the red CPU EZ Debug led, there is bound to be something wrong with the CPU or its connection to the motherboard. I would remove the CPU for testing in another AM4 motherboard that accepts the 5800X3D and has BIOS that accepts the 5800X3D. It does not have to be an X470. Also, with the 5800X3D removed, I would very carefully inspect the pins on the 5800X3D and the pads on the motherboards again with good lighting and a magnifying glass.
I suppose the versions you have successfully tried using the 2700X that are AL and later, such as the latest AMA are "stable".
Thank you. Unfortunately, I don't have another MOBO that will accept the 5800X3D. I have since returned the 1st 5800X3D. If the 2nd one does the same thing, I will investigate the MOBO even more. I may find someone at work with a MOBO and this CPU and ask them to test it for me. I have read on GOOGLE (Gemini*) that others with my MOBO have struggled to get this CPU to POST on their older X470. It does say any BIOS version with AGESA 1.2.0.7 or newer. It has also said that users with my MOBO have had good luck with AGESA 1.2.0.7v, which is the vAL BIOS firmware, not the latest. There are so many options; I will just have to work through each and see if I can get the 2nd one to work.
You still haven't listed details about your HW used.
>>Posting Guide<<
I will do my best to list the HW in detail. I don't have access to my gaming PC atm. I try to post this stuff while I'm at work because I have a busy home life. So please forgive my missing details. I'm trying my best!
HW:
CPU:
AMD Ryzen 7 2nd Gen - Ryzen 7 2700X Pinnacle Ridge (Zen+) 8-Core 3.7 GHz (4.3 GHz Max Boost) Socket AM4 105W YD270XBGAFBOX Desktop Processor​
With a 240mm AIO cooler, Cooler Master
GPU:
PowerColor Fighter AMD Radeon RX 6700 XT Gaming Graphics Card with 12GB GDDR6 Memory, Powered by AMD RDNA 2, HDMI 2.1 (AXRX 6700XT 12GBD6-3DH)​
MOBO:
MSI PERFORMANCE GAMING X470 GAMING PLUS AM4 AMD X470 USB 3.1 HDMI ATX AMD Motherboard​
Ram:
G.SKILL Aegis 32GB (2 x 16GB) 288-Pin PC RAM DDR4 3000 (PC4 24000) Desktop Memory Model F4-3000C16D-32GISB​
BIOS: E7B79AMS.AM9
PSU:
It is a 700 Watt Power Supply. I can't remember the Brand; I'm sorry :(
OS:
Windows 10
Try figure if possible the exact brand and model.
Have you connected both CPU_PWR1 and CPU_PWR2?
Try boot with 1 memory stick only in DIMMA2 slot and retry with the new CPU.
Is this old CPU or from the new refreshed version of 10th Anniversary Edition?
1.) CPU_PWR1, the 8 Pin connector. I will try to get the actual brand when I get home. I know it is not a modular one, so It's on the older side. before 2023
2.) I have tried booting with 1 stick in Slot A2.
3.) the 5800X3D is the 10th Anniversary Edition
Are you trying to boot with 5800X3D CPU in UEFI mode? not CSM
I'm pretty sure I tried both UEFI and CSM. I know that once I put the Ryzen 7 2700X back in, I needed to go back to CSM. I also had Resizable BAR enabled and over 4 G coupling enabled and I enable A-XMP for the RAM. With the 5800X3D in. I have tried all the combinations.
I don't have another DDR4 RAM stick to try. My replacement 5800X3D will be here tomorrow. I will try everything I did with the first one. My concern was the E7B79AMS.AM9 BIOS with AGESA 1.2.0.12 isn't the right BIOS, or it has trouble with my old X470 and the NEW 5800X3D?
Got it.
Any above(including) 7B79vAL should works,
generally the latest one is recommended. [7B79vAMA]
It's not clear what's the issue.
When installing the new CPU (check the PSU details)
and ensure the CPU cooler doesn't do too much pressure on the CPU/CPU socket.
Got it.
Ok thank you. I also tried the latest BIOS E7B79AMS.AMA, with no luck either. I also inspected the Pins on the 5800X3D with an eye loupe; all pins look good.
I also inspected the socket as best I could with the eye loupe. I did have some thermal paste that was on the pins and socket. I cleaned it with 100% alcohol and dried it with a can of air. Everything works with the Ryzen 7 2700X installed. IF this second 5800X3D has the same issues, I will dive more into the MOBO and the socket itself.
