Problem: Continuous power cycling every 25 seconds.
Equipment:
Mainboard: New X58 Platinum MS-7522
PSU: Silencer 610 Watt EPS12v by PC Power & Cooling (part of the OCZ Technology Group)
RAM: 4GB total on two, 2GB Fatal1ty PC3 10666 (PN OCZ3F13334GB) 9-9-9 @ 1.7v cards
CPU: Intel i7 Quad Core with stock fan
GPU: Asus EAH-4850 ATI Radeon HD with 512MB DDR3 mem.
HDD: Western Digital WD750GB (WD7500AAKS)
BIOS: Unknown at this point
When both of the 2GB DDR3 memory cards are removed the systems stops power cycling and stays running. When I put one of the two 2GB DDR3 cards into A0 it starts power cycling again. I have tried both cards separately with the same result. I do not plan to overclock the CPU and so have left the DIP switches in manufactures default positions. Do you know if the Fatal1ty DDR3 cards are incompatible with this motherboard? If not can you recommend an alternative DDR3 memory card that works with this motherboard? Or can you suggest how to get these Fatal1ty cards to work? OR Is the DDR3 mem. even the problem????? I am open to all suggestions.
FYI, this is the first time I have built from scratch and not real technically knowledgeable - yet.
Thanks for the help.
Equipment:
