Good evening.
My original setup was:
MSI X58 Pro-E, running V8.14 BIOS (think it's listed as 8.E on MSI site)
i7 920
6GB (3x2GB) of A-Data DDR3 1333 (Part number HY63I1B16)
eVGA GTX 285
Win 7 64bit Ultimate
I tried to find the exact brand/model of memory to add, but was unable. I ended up buying this: http://www.newegg.com/Product/Product.aspx?Item=N82E16820211451
I installed the memory and BIOS saw it all. Windows started up fine, reports 12GB, but the 2nd night after installing the memory, I got a bluescreen. I went ahead and ran memtest86, which reported several errors.
I took quick pic of memtest86 showing several errors here:
Before I RMA the memory, I wanted to make sure it isn't a configuration issue, rather than just bad memory.
Here's a pic of the memory tab from CPU-Z:
SPD tab (slot #1 "old" memory):
SPD tab (slot #2 "new" memory):
And here's a pic from SIW's memory tab:
What do you think? Bad memory or configuration issue? Thanks for your time.
i7 920
eVGA GTX 285
