- Dec 15, 2010
I just built a computer with mostly new parts. I'm using a x58 pro-e mobo with a core i7 950 cpu and a Geforce 240 graphics card. I put 3 brand new corsair xms3 DDR3 1333 2GB RAM in there. Using a 650W almost brand new power supply that I know is good since it's out of my old computer. When I turn on the power, the fans come on on the case, and the cpu and power supply fans also come on. The LEDs all look good, with the PCIe LED blue and the power LED green. The problem is, nothing shows up on my monitor. I don't know if the problem is that the computer itself won't even boot to BIOS or if the graphics just aren't working.
Any ideas? Do you think the motherboard could be bad or something?
Any help would be great. Thanks,
