All,
I took a risk and got an Asus U3S6 card at Amazon for $25. Yea, I know it says you need an Asus board! I wanted to add more SATA ports and have full-bandwidth USB3.
It's really not a big deal anymore as I found a 90-degree SATA cable and can now use all 7 ports. Also, the USB3 card is in the x4 slot, so the USB3 chip is getting PCI-E 2.0 bandwidth so it's not limited anymore or anything...but I still have the card.
When I put this card in, the system won't post unless I have the stock 133Mhz BCLK, but it won't boot with any SATA drives attached. At my normal 186BCLK the system does not post.
Just curious...maybe the necessary BIOS support will be added as I know MSI makes a similar card, although I guess not in the US market.
Also, liking the Pro-E. While it doesn't have the complex power circuits as more expensive boards, I have found it is efficient and allows good overclocks. I run 3.9 (4.3 at full TB) with a +.06V increase only. The IOH was hot, but I replaced the thermal solution...although it's still hot...at least it's stable. Also, running it with 2*GTX470s clocked at 725 instead of 607.
Thanks in advance...
