- Apr 28, 2009
Built a new system. It is completely stock right now, and I was just trying to make sure the build was stable. Seems to be ok most of the time when just using normal applications. When I tried to run Everest System Stability test, it would either freeze up completely, or restart. The prime95 small fft seemed to run ok, but when I tried to run the blend torture test, the same thing would happen as well. I ran memtest86+ 2.11 and it went through many passes with no errors detected whatsoever.
Please help! much appreciated.
Specs
- Core i7 920
- MSI X58 Pro BIOS version 7.1
- Corsair 6gb DDR3 1333 (PC3 10666) (TR3X6G1333C9)
- Sapphire Radeon HD 4830
- OCZ 700 MXSP PSU
Specs
- Core i7 920
- OCZ 700 MXSP PSU
