- Oct 18, 2009
good day my friends.
i Tried my best to comply with the rules. please forgive me if i forgot something.
here is my screenshot:
THE problem :
everything is fine ,when i only use only one chip in (A0)
but when i use 2 or 3 chips ,the system becomes unstable ( lockups,freezes,random boots, in defferent places and times, some time even in windows startup,)
i used Clrcmos button between changes and no luck. ( it helps in restoring the settings so i can use my (1GB ram in stable condition)
i tested all the chips with mem test (individually) with no errors for a good number of passes
i tried to play with voltage and ram setting as recommended in some threads without luck.
I am really reaching a point of desperation here ,
please help me.
Q : can I use 4gb chip in A0 and finish my problem?, my system is 32 bit, so can i go around this problem and use 4 gb in one slot ,and will that end my nightmares??
and thank you in advance.
p.s.: my system is newly build
i tried different rams with no luck
the only old stuff i still have is my usb keyboard and mouse.
I am no technician and i have very minimum knowledge about it
THE problem :
please help me.
