Sorry, meant I had received the Thermalright Ultra-120 Extreme RT 1366 cooler I ordered on Friday and I installed it, I also put Arctic Silver 5 on. I installed last night, and computer has only been on about 4 hours so the Arctic Silver 5 has not had time to make a good bound between the CPU and Heatsink. I was thinking about that in the overclocking area. I am looking at other forums and interacting with those on Overclocking the CPU, but I figured I would ask you 2 since you 2 have been able to help me so far.
@joker, no I did not take the Heatsinks off, yet I found the nylon bolts but I wanted to ask you about the pins on the motherboard. Did you break the bottom of the push pin off? and pull it out or were you able to pull them out? I did not want to break them and then my bolts not fit, since I have some nylon bolts, not metric though. I got size 6, washers hex nuts and bolts. I do not have package up here so I will look and get back to you on size, want to make sure I have the right or close enough size before I take them off, I think they are close enough.
One more question, I was running LinX to stress my CPU and my temps from Core 0 to Core 3 there is a 8 degree difference. Seems high to me, with my old CPU cooler my temps were about 4 degrees different from those 2 cores, now double. Could it be since the Arctic Silver is not bounded, or my heatsink is not flat, maybe convex?. I did not sand it down to make it flat. I wanted to see what my temps were 1st and if I was unhappy then sand the Heatsink. Just seems like a big temp difference to me.
@mechsner
Those voltage were just thrown out there, say worst case situation, if I had to push the CPU that much. I do not plan on going that high, but I want to know what QPI limits were and if I were to pass the recommend value, what to do. I have been doing things to see what works best, so I will inform with progress.
So far I have not overclocked any more.
