- May 10, 2011
Hi Guys!
I recently assembled a new system, with the following components:
MSI X58 Pro
i7 950
2x Strontium DDR3 4GB 1333MHz [SRT4G86U1-H9M]
ASUS EN8600GT 512MB
Sunpro ATX-550W PSU
When I attempt to boot, the system powers up, all fans, optical & HDDs run for about 10 seconds before turning off then restarting and doing the same thing 5 seconds later. There is no there is no display, no system beeps, the keyboard lights don't flash etc. However, the system will post and boot fine if I hold the CMOS Clear button down while I press the power button, which means the the CMOS must be cleared every time the system is booted, which is very irritating. I've breadboarded the motherboard, it does the exact same thing when on a piece of cardboard with any combination of hardware, including from bare CPU, one stick of RAM, graphics card and keyboard. I've swapped the PSU with a lower capacity one (it's all I had) and the same things happens. The system performs fine once booted. I have rum memtest86 for a couple of hours without error and flashed to the latest BIOS but it has had no affect.
Has anybody experienced/solved a similar problem? I'll try using different RAM or graphics when I can borrow them off a friend but at the moment I'm all out of ideas :/ This is doing my head in!
Sorry for a massive first post, any help would be greatly appreciated!
EDIT: I should also mention, the system restarts fine without requiring a CMOS clearing, however when it's turned off and left for more than 10 seconds, it requires clearing of the CMOS.
MSI X58 Pro
i7 950
ASUS EN8600GT 512MB
Sunpro ATX-550W PSU
