Hi, I have just built a new system with the specs as follows:
i7 920 (D0)
2x1gb Corsair XMS3 1600
GTX260
MSI 58M
power cool 650W
The system has no output, it powers on for 20 secs then reboots in a constant loop.
The gfx card works in another system.
i7 920 (D0)
GTX260
MSI 58M
power cool 650W
Clear CMOS (with power cord removed), use '1' stick in the black slot (A0) (second slot from CPU), disable Spread Spectrum, & then test. Usually, most compatible RAM for i7 X58 is triple channel kits. Are you sure your RAM is correct? It should have a voltage rating of 1.5 - 1.65v's.
