X670E Ace Bios Problems
BiscuitBomber
Active member
Hardware:
Processor: 7950X
Motherboard: MSI X670E Ace
GPU: EVGA 3080 TI FTW3
MEMORY: G.SKILL Trident Z5 Neo RGB Series AMD EXPO 32GB (2 x 16GB) 288-Pin PC RAM DDR5 6000 (PC5 48000)
PSU: EVGA 1000W P6
Cooler: 360 Phanteks AIO MPH
After updating my BIOS today on my PC. When booting up I was getting BIOS Code A6 and the RAM light was staying Amber. This didn't occur on the previous BIOS 7D69v13. I attempted to clear CMOS but same issue. I ended up downgrading my BIOS back to 7D69v13. I opened a ticket with MSI, but just a heads up in case anyone else runs into this. Before 7D69v142 I had zero issues with RAM and bootup problems.
EDIT Title
Alan J T
I wrote to the msi support and they are not going to fix it. they answered me that if my motherboard needs a replacement I need to contact the seller.
What a good answer for A BIOS issue.
This is my last MSI product, you can be sure.
That is really a really shitty reply from MSI. If this is the case and I don't doubt you, this is my first and will be my last MSI motherboard. If Asus and Gigabyte can fix this, then so too should MSI.
I'm still running my 7900XTX but i'm curious : is the pci-e issue impacting everyone using a 5.0 dGPU here ?
Not everyone, but there are with all types of CPU's and GPU's. Both Nvidia and AMD PCI-e 5.0 x16 can boot up at PCI-e 1.1 and stay locked at that speed. Can also boot at 2.0 and 3.0 and 4.0, but they stay locked at those speeds until you do a reboot. It usually comes right and you get the full speed on the second boot. But sometimes i've had to reboot up to 4 times to get the full 5.0 x16 mode.
I see. In the worst case scenario they are usable normally after a few reboots. Knowing the price point of the motherboard it's definitely shameful.
New, presumably BETA version released: 7D69v1P1
Description:
- AGESA PI-1.3.0.1b updated.
- Optimized with AMD EXPO Technology: Featuring Ultra Low Latency.
Not taking the chance myself yet, still on 7D69v1M which have been solid for me.
Description:
Thanks. Will test it now and report back. But my build was kinda 10000000% stable already without any major kinks (except maybe of lower memory speeds)...
1P1 beta :
Behaves and looks normal - similar to 1O7 and 1O8.... they cleaned up some menus (e.g. some items are now packed in sub-menus) but not much else...
Stability-wise -- my GPU is PCIe and is running normally in 16x4.0 mode... My 5.0 SSD just tested and behaves also within 5.0-specs....
But this was never my real problem. Haven't stressed my memory OC yet... just added the settings that were stable in previous versions already incl MCR.
I'm about 10hrs in with the latest 7D69v1P1 update and things seem stable. I've gamed and didn't see any performance issues, ran Memtest5 while running GPUz Rendering in the small window and large. The small window dropped to 2.0 but I'm not taking that as a bios problem. The large windowed GPUz render test stayed in 5.0 mode. Mouse seems stable. Haven't heard any audio robotic type sounds. This might be the one that fixed the issue. However time will tell.
EDIT: yep spoke too soon.. went from 87 nvlddmkm errors to 93 on this latest cold boot. game crashed.. desktop stuttered.. mouse dropped out or call it stuttered. btw I'm using a cl26 6000 kit
Debugged with Gemini the MSI x670E ace bios bug which was not solved since 2024 (you can see my other messages on my account)
BUG REPORT: POST Code 10 after AC Power Loss with RTX 4090 (Workaround Found)​
To the MSI BIOS Engineering & Development Team,
I am writing to report a specific, reproducible early-initialization bug regarding MSI motherboards paired with NVIDIA RTX 4090 graphics cards, occurring strictly after a complete AC power loss.
Hardware Configuration:
  • Motherboard: MSI MEG X670E ACE
  • CPU: AMD RYZEN 7950X3D
  • GPU: NVIDIA RTX 4090 (Latest VBIOS firmware applied)
  • BIOS Version: Latest available version (May 2026)
The Issue (Symptoms):When the system experiences a complete AC power loss (unplugged from the wall or PSU switch turned off), the subsequent cold boot results in a hard hang at POST Code 10 (PEI Core is started).The system refuses to boot further. The only way to recover the system and successfully POST is by performing a hard CMOS reset.
Isolating the Variables (What was tested & ruled out):
  1. Memory Training / MCR: The issue is not related to memory training. "Memory Context Restore" (MCR) was completely disabled during testing.
  2. GPU Firmware: The RTX 4090 has the latest NVIDIA UEFI Firmware Update Tool patch applied.
  3. PCIe Gen Settings: Manually locking the primary PEG slot to PCIe Gen 4 (instead of Auto) did not resolve the issue.
  4. GOP / Visuals: Disabling the Full Screen Logo and Info Block Effects had no impact.
  5. Cross-Vendor Testing: The exact same RTX 4090 boots perfectly fine after an AC power loss on a motherboard from a different vendor, indicating this is specifically an MSI BIOS/logic issue.
The Solution / Workaround:The issue was completely resolved by changing ErP Ready from Disabled (Default) to Enabled. With ErP Ready enabled, the system successfully passes early initialization and boots normally even after a complete AC power cut.
Technical Hypothesis for the MSI Engineering Team:This appears to be a PCIe Link Training timeout/conflict occurring during the PEI phase. When ErP Ready is Disabled, the motherboard maintains 5VSB standby power. Upon an abrupt AC power loss, the asynchronous capacitor discharge between the MSI motherboard and the massive RTX 4090 seems to leave the PCIe bus or motherboard logic in an undefined state. When AC power is restored, the BIOS attempts early hardware polling, the GPU fails to respond within the expected MSI timeouts, and the system hangs at Code 10.
Enabling ErP Ready forces the motherboard into a true "Zero Power" state, ensuring that upon AC power restoration, the PCIe initialization starts entirely from scratch, allowing the RTX 4090 to be polled correctly.
Request: Please review the standby power handling (5VSB) and PCIe early initialization timeouts (Link Training during PEI) following abrupt power loss events for 40-series GPUs. A microcode adjustment in a future BIOS update would prevent other users from experiencing this lock-up without having to manually enable ErP Ready.
Thank you for your time and continuous work on BIOS updates.
I have had trouble with this X670E Ace motherboard dropping Internet connection, but only temporarily. I have heard that was a known issue with this board. Any advice?
Since I always keep my ErP Enabled even when doing a bios flash I'm going to do some testing with ErP Disabled with this 7D69v1P1 bios. Will report back.
EDIT: Astral 5090, Seasonic Titanium 1300, AE-7 Sound card bottom slot..
EDIT2: Enabled means nothing is getting power, Disabled means things like USB devices and other things can start the computer etc.
I'm running 7D69v1P1 since three days now with the same settings I was using on Agesa 1.2.x and it seems stable for now... finger crossed.
yes you need to update the NIC drivers... the Ace use the Aquantia 10GbE...
There's an update for Marvell NIC, v3.1.11 10-17-2025
Thanks MEG X and sblantipodi!
I had updated to v3.1.10 some time ago. Now I am on v3.1.11. This thread has been a lifeline!
Here is the NIC driver link with instructions for anyone else:
Ethernet Driver for Aquantia 10GbE Network Adapter
Here is the actual page to get the driver:
Marvell
Category = Marvell Public Drivers
Part Number = AQC107
Are there any other known more updated drivers for this motherboard that are NOT on the main MSI driver page?
