some feedback after few days with the latest 184 bios 1.0.0.7a
6200C28 at 1.24V SOC (I won't go over 1.25 even if the safe point is considered to be 1.3V "now" )
Other voltages have been further lowered from stock:
VPP 1.95V -> 1.8V
VDDP 1.15V -> 1.10V
unlinked VDD/VDDQ/VDDIO
VDDIO 1.35V -> 1.20V
VDDQ 1.35V -> 1.34V
Only voltage increased is the VDD for the ram, but that's on totally separate circuit, should be ok as long as the ram is stable and doesn't overheat (1.35V -> 1.44V)
Everything stable after 20ish Testmem5 1usmus cycles
Tested also 1 hour y-cruncher VST for fclk 2167 stability (check latest buildzoid video about infinity fabric stability)
For every day use I will stick to 2133, still a bit unclear how to detect properly fclk instability without an oscilloscope, better stay safe.
PBO CO -15 all cores, no problems, infamous aida sha3 test doesnt crash (some unlucky cpus crash @ stock settings xD )
There's still the same old bug with fmax boost override PBO option that breaks entirely CPPC on X3D cpus... but that I think it's not a bios bug, it's more like AGESA's fault.
I know this option is half useless on dual mixed CCDs, but it breaks many things and need fixing from amd. No hurry, it will be completely useless if the cpu burns before XD
VPP 1.95V -> 1.8V
VDDP 1.15V -> 1.10V
VDDQ 1.35V -> 1.34V
