I've had the X670E Ace for a couple of months and have not had any issues using USB-C DP during that time. This morning, it doesn't work anymore. When I plug the monitor in, I get a message on the PC stating "Display connection might be limited." Audio passthrough is working for the connected device but the display is not detected. I've updated the iGPU drivers which did not make a difference.
I have tested the display on my Steam Deck and MacBook and the display works on both of those - so the problem is only with my desktop using the X670E Ace.
I don't see any Windows updates occuring since 5/13 and the only recent change I've made was a BIOS update about 4 days ago, so this has worked since then.
Anyone had a similar problem or have any suggestions?
Thanks
Thanks
