crazylord20015a002e3
- Feb 1, 2025
Hi! I have a problem with my motherboard. So, i have my GPU in the MOBO top PCIe slot, and randomly on restart or boot up, my GPU will run at PCIe x16 1.1 or 2.0 instead of x16 4.0, and this causes stuttering to the point of the system being unusable, and the only way to fix this is restarting the computer until my MOBO decides to let the GPU run on x16 4.0. I have tried forcing the PCI-E1 slot to only use gen4 (in BIOS settings) but the problem still occurs. On the other hand, if i force it to run only on gen3, then all is fine and it never changes to any other gen on restart. What can be the cause of this problem and how can i fix it? I've been struggling with this for a month now and i've run out of ideas. I even replaced my GPU once thinking that was the issue, before realizing it was from the PCIe.
Specs:
MOBO: MSI x670e gaming plus wifi
GPU: Gigabyte 4080 super gaming oc
CPU: Ryzen 7 7800x3D
SSD: Lexar M.2 PCI 4.0
RAM: 2x16GB Patriot Viper 6000 series
Using latest BIOS version (7E16v19), i've tried other versions as well but no change..
Can anyone help?
Specs:
Can anyone help?
So starting to play with the CPU boost and undercoat. A24 on the carbon wifi 870. WAY better experience than when I built mine.
