X670E wifi not booting
craven50015ae02e6
MSI MAG Tomahawk wifi X670E
("AMD Ryzen 9000 desktop ready")
CPU: 9700x
RAM: T-Force Delta DDR5 6000MHz 2x16GB
Power Supply: RM850x
The most hopeful screen I have seen is the processor being listed and having "delete" listed as what to press for the BIOS. There it will go to a black screen before I can read everything. I have had it freeze up on the screen. Right now the green trouble shooting led is on.
The motherboard has a "bios flash button" but no port marked for it. But I try the top port nearest the button and wait 20 minutes. No change. There is no visible red led. I try a bottom port and I see a red led. It's activity duration last seconds. No change.
I have checked the RAM positions. The 2nd and 4th slot going away from the processor.
I have tried just the 2nd slot.
I have re-seated both RAM modules.
I have re-seated the cpu.
I shall check my wiring again.
Are there any trouble shooting steps I can take?
All I have are the 4 fault code LEDs. Three of them will come on momentarily during boot up.
Better update to the latest BIOS to support 9000 CPUs.
What is your MB model name? X670E WIFI is not a full name.
I tried just using the cpu, and one ram stick. That got me to the bios.
Now I am going to update the bios. Then add one part at a time.
I'll guess it is the video card that I waited 5 months before buying.
The pc won't boot with a Sapphire Pulse AMD Radeon 9070XT installed. This is the last component. The green fault LED is on (BOOT - indicates the booting device is not detected or fail). I have no idea why that would be. The GPU requires a 750W PSU. I have a 850W.
Try to set PCI_E1 slot as Gen 4 in BIOS then check again.
The MB might automatically set graphics card as Gen 5 which is not compatible to all graphics cards.
