jonjon12315c602ec
- Oct 4, 2025
I've posted before about this issue in other threads and other subreddits, and from what I can gather this is specifically a problem only on MSI X870/X870e boards when paired with an X3D processor.
Basically, when the system has been shut down for some time, on start up the sound lags, the screen becomes laggy/jittery and 50% of the time the system crashes if you don't restart. From checking various threads it seems that it's an issue that was introduced in a BIOS revision where the main PCIe slot is forced to work at x1 speed. This happens at completely random times, it can be fine for days and then happen twice in a row.
I did so much troubleshooting before realizing it was a BIOS problem, I changed GPU, PSU, M.2 drives and upgraded from a 7800X3D to a 9800X3D along the way with the issue persisting. I've tried different BIOS configurations, and a fresh windows install didn't help either.
Before realizing it was a BIOS problem I contacted MSI and told them about the issue, where they offered an RMA which I didn't take, as I was worried the problem would just persist on another board. MSI are now trying to say it's either a GPU problem, or suggesting it may be due to having an M.2 occupying the M.2_1 slot which makes no sense whatsoever, nothing should share bandwidth with the main PCIe1 slot as far as I'm aware.
I'm trying to tell MSI that it's clearly a BIOS issue and they need to look into a firmware update rather than an RMA, but they seem to be skirting around accepting this or even entertaining the idea.
Here are some other threads I quickly found detailing the same or similar issue;
https://www.reddit.com/r/MSI_Gaming/s/RNM8QYUgAw
https://www.reddit.com/r/MSI_Gaming/s/MlQIcURoa1
https://forum-en.msi.com/index.php?...cant-seem-to-fix-no-matter-what-i-try.406992/
And my personal experience;
https://www.reddit.com/r/MSI_Gaming/s/oZLtJUyo5F
If you have experienced this, and can tell me what the last stable BIOS was, I can feed this back to MSI and push for a fix. I also suggest you log a ticket too, the more eyes we have in it the better the chances for a fix are.
