X870 Wifi not detecting front usb ports in Bios
Vintrus
Hi all I am having an annoying issue with my front USB ports in the Bios under A44 I cant Boot from flash drive i am trying to boot into a linux disto however the bios wont show the drive but every thing is working properly in windows ll I can see the drive use them its only the boot from menu being strange.
when you press F11 upon bootup, can you see your bootable drive?
does it only happened in Front USB?
Yes it does boot from rear ports. . The front ports booted fine on the A4 bios when I moved to A44 thats when the ports stopped detecting the flash drives.
can you confirm exact model of the motherboard you are using as I can't see any A44 bios in msi webiste?
so seems that A44 is causing this issue but older bios A4 is ok
