ilkayercan57
- Oct 6, 2026
Hello dear friends, I hope you are having a good day. For the past 2 months, there has been an unimaginable problem with my computer.
Problem: In June, I bought an MSI X870E Carbon Wifi and a 9800x3d. I set it up, my computer components are:
4070ti super, 9800x3d, X870E Carbon Wifi, Corsair 6000mhz cl36 2x16 32GB, 1000w plat psu, m2 ssd corsair mp600 nh pro 2tb
I used it smoothly for about 1.5 months. When the date reached July 23-24, while playing Valorant, my computer weirdly froze and locked up for around 5-6 seconds. When it came back to itself, a periodic stuttering/hitching problem was clearly visible. When I first installed it, I had disabled the 2nd Ethernet port (5G). The problem caused by that was resolved. Afterwards, I faced this problem. Minor rough patches started to happen in every smooth game I play. League of Legends dropping 5-10 fps and hitching, in Valorant and CS2 sometimes minor rough hitches during the game, and when I die, while spectating any teammate who has a good PC and internet, I started seeing them as if they are hitching or lagging, when I asked them, they informed me that there was no problem on their end. Whenever I die and watch another player, I see them hitching or my computer hitching. Frankly, my internet is not bad, but I constantly started experiencing packet loss. In CS2, telemetry data up and down arrows increase more when I die, and I think the reason I experience this in CS2 and other games is this. The problem started after my computer momentarily locked up and recovered on July 23. Before that moment, there was no problem either while watching someone else or while I was playing. Games with loaded shaders started to stutter, smooth FPS games started to stutter and break their smoothness. I tried everything you can think of. Within 2 months, this situation started to ruin my inner peace. The computer I normally used smoothly is now bringing ridiculous minor rough patches that break smoothness, even if small. I don't know what is causing it, but the solutions I tried are as follows:
My BIOS, drivers, chipset, all kinds of software are up to date, I even started experiencing rough patches on the versions I used smoothly 2 months ago.
Frankly, I started getting very uneasy because I will not be able to find what the problem is in any way, and I got very tired both physically and mentally.
My computer has Lian Li fans and a Tryx brand AIO. There is no problem with my temperatures either, while doing these tests I did not activate any device monitoring/monitoring service. I tested while they were off.
I am exhausted now, I would be very pleased if you could help please.
Sorry for translate..
- - 2 times clean format and Windows installation
- - Modem and internet package change / speed upgrade
- - Trying various graphics driver versions using DDU
- - Different BIOS version
- - Trying settings like C-States / Spectrum / EXPO inside BIOS
- - Attempts like turning off Monitor DSC / cutting Hz in half
- - Gsync / Hags ON / OFF trials
- - Unplugging USB devices and testing
- - Ethernet cable replacement trial
- - Fixing PCIe, m2 data paths to gen4
