Ticket:
USB C PD Charging - No dice
Content:
The wattage output is just (V) x (A). 5 volts x 5.4 amps = 27 watts. It is not specified as a PPS in the user manual, only PD. Rear ports are not rated for PD, no.
It would depend on whether or not the phone is capable of simply drawing 27W or if it's trying to pull more. I don't personally know enough about smartphones to analyze that, but presumably since they can charge off of regular USB chargers, they should be able to. It sounds like a hardware problem, but ultimately we won't be able to tell unless you send it in.
I use x870e Carbon wifi currently using BIOS ver. 1A23 and the problem isn't fixed, before the 0104 PD FW update it was disconnecting frequently and not charging properly but NOW after the 0104 update the type-c port completely disabled i can't connect anything no response. Anyone else still having issues on x870e carbon wifi? cause i still have issues. Any fix/suggestions?Yes, the download and install problem with PD firmware from Live Update is now fixed.
After upgrading the BIOS to 7E49v1A27, I checked if there is any PD firmware update and it seems like there is (version 0105). After the PD update and restart the issue solved for me.I use x870e Carbon wifi currently using BIOS ver. 1A23 and the problem isn't fixed, before the 0104 PD FW update it was disconnecting frequently and not charging properly but NOW after the 0104 update the type-c port completely disabled i can't connect anything no response. Anyone else still having issues on x870e carbon wifi? cause i still have issues. Any fix/suggestions?
I found this thread while searching for info on Google about the same issue. I am currently experiencing it with a Z890 ACE motherboard and a S4 Ultra.
BIOS version 7E22v1A4
The issue seems to manifest when the charging power exceeds 25 watts, and it appears to only affect my phone as I was able to charge a battery using the full 65 watts.
If you disable C-STATE in BIOS, you won't be able to use core BOOST, so you will end up for example running 9800x3D exclusively at 4700 mhz.any of you tried disabling C-state in bios?
are you running expo stock? might have too much/not enough SoC v, at least those are the only times i got disconnects on builds with amd
