krzysztof.podkalick15c802e6
- May 20, 2025
Hi, around a month ago I've built a PC with following specs: https://pcpartpicker.com/list/sG42np . Pretty much from the start I've been struggling with constant freezes while using it. There were no rule on when and how often they would happen. Freezes would happen while gaming, just browsing the web or even when the PC was just idling. Everytime it happened I had to restart the computer and after logging in into Windows it sometimes would happen again and sometimes my PC would work normally for some time. The only errors I was able to find in the Event Viewer were about my PC being shut down improperly. Also, I didn't get even a single BSOD.
Initially I thought that it might have been caused by a mild undervolt but none of the following steps fixed the issue:
- reverting the undervolt
- disabling EXPO
- upgrading the BIOS
- upgrading all drivers (including chipset, GPU)
- clearing CMOS
- uninstalling unnecessary apps (e.g. MSI Afterburner)
- re-installing Windows 11
Finally, few days ago I've stumbled upon THIS REDDIT POST in which the author complained about a similar issue. It turned out that the fix that they are talking about fixed this issue for me as well even though they are using a different motherboard. So, after changing the "PCI_E1 Gen Switch" BIOS setting from "Auto" to "Gen 4" the issue disappeared completely - for over a week now I haven't experienced a single freeze.
Is this a known issue with this motherboard? Is there a fix for it? Could this be an issue with GPU and not with the motherboard itself?
Thanks!
- disabling EXPO
- clearing CMOS
Thanks!
