Hello, I bought the X99S GAMING 9 AC motherboard but have ran into some issues.
The computer won't boot when I put my second MSI GTX 980 Gaming 4 GB card in the last PCEI 3.0 port (PCIE port 5) and I get the debug LED message 94 on the motherboard. I have a SLI setup.
The first card I have in the second PCIE 3.0 port due to the Noctua U14S CPU fan takes up space for the first slot. So I have been running my grafic cards in PCIE slot 2 and 4 with some issues.
First the card in slot 2 gets really warm over 86 celsius. And second: SLI runs really poorly in World of Warcraft. I get a lot higher performance with just one card activated. I am not sure if it's cause I am not running my cards in the recommended PCIE 3.0 ports or because WoW has some issues with SLI, but I heard other people have no issues at all with WoW in SLI.
I got the same issue with 3Dmark firestrike, the cards perform really poor in SLI. I get higher score with SLI turned off..
Though SLI seems to run pretty well in 3dmark 11 and Diablo 3 Reaper of Souls.
But the main issue right now, is that the computer won't boot with the grafic cards in PCIE port 2 and 5. The solution to run them next to each other is not good, cause it gets really hot and I get bad performance in WoW and Firestrike.
Picture of my setup before I switched places with the grafic cards as you can see, it is really tight:
Any upcoming bios updates (got v1.3) that will solve this issue on the horization? Hopefully this get sorted out really soon..
My whole computer setup:
Intel i7 5820K | MSI X99S Gaming 9 AC (bios 1.3) | SLI MSI GTX 980 Gaming 4GB | Samsung 850 Pro 512 GB | WD Red 4TB | G.Skill Ripjaws DDR4 3000MHz 4x4GB | EVGA SuperNOVA P2 1000W | Noctua NH-U14S PnP | Fractal Design Define XL R2 | 5 Noctua NF-A14 PWM 140mm fans | Windows 7 Pro 64 bit
