Xbox Series X 1440 120hz issue
manufan_015ff02fb
Hello all,
I can’t seem to get my get my Xbox series x to run at 1440p on 120hz I’ve had the same monitor in the past and it worked fine I’ve got the msi optix G321CQP curve. It only runs at 1440 on 60hz when I change it to 120hz it changes the resolution to 1080p.
anyone got ideas on how to get it to run 1440 at 120?,
thanks in advance
manufan_015ff02fb
Hi
According to the product page, MSI only talks about "optimisation" for PS5.
Have you tried different HDMI cable?
Take a look in the OSD menu, possibly there is a preset to switch to higher refresh rate.
Yeah I purchased a new gold one as I told they’re a lot better I’ve had a play with the settings and can’t see an option to change the refresh rate
idigby333159102e4
Hi I have the same monitor and the same problem and just can not get it to run 120hz at 1440p no matter what I try and I have tried so many different things that I have just given up .I just don't think the hdmi is supporting 120hz at 1440p on Xbox series x
