I
isimpson
Guest
Having managed to get XP 64 bit working ok on my new machine I thought I should upgrade my AMI bios on my K8t Neo Fis2r MoBo.
I upgraded from 1.1 to 1.2 and now XP 64 bit will not boot!
It will work in safety mode but not normal, so I suspected a driver.
Removed all the drivers and that did not work so I decided to reinstall the OS.
And now during the OS setup it just hangs!!!!
My bios settings are the same the only difference is the bios version.
Has anyone else had this problem or got a soloution???
System spec:
CPU: Athlon64 3200+
MoBo: MSI K8T Neo fis2r
RAM: 2 x kingston cl3 512mb
HDD: seagate 160gb SATA
Video: PNY geforce fx 5600
System spec:
CPU: Athlon64 3200+
