I had the mouse button on the end test just incase it went higher. And that is with a 160 WATT TDP cooler AMD way under spck the thermals on the CPU 105 watt TDP my Ass95c on cpu? Are you trying to melt it?![]()
Are you saying AMD do not thermal throttle??I had the mouse button on the end test just incase it went higher. And that is with a 160 WATT TDP cooler AMD way under spck the thermals on the CPU 105 watt TDP my Ass
They are supposed to since then I have changed mine to manual and not auto set it to 96c to start to throttle. The are two sets of OC setting in the AMD bios one by MSI and One by AMD I would so like for MSI to totally gut out the AMD OC setting But I think they are needed for Ryzen Master. But having two sets of controls in the BIOS for OC and Memory setting is just dum. And may be why some have so much trouble.Are you saying AMD do not thermal throttle??
And with a bit of testing an research the AMD Ryzen 9 3900x had a TDP of almost 190 watts. when cranked to All core OC of over 4400Mhz The Ryzen 9 3950x has a official AMD TDP rating of 105 but in reality have seen them hit over 200 watts So ya AMDAre you saying AMD do not thermal throttle??
