Z 370 Pro-A
mryuetten
CORPORAL
All functions keys are dead same for esc an delete . Cannot install Windos10 via usb or dvd after crash. Completely gone except for recovery page but nothing works there, Is there a reset to deault button on must I goes to motherboard with your instructions how or what?error code 0xc000000f
badboy2k
Active member
can you make a new USB installation disk and make sure the USB is formatted to NTFS before you install as that is usually you have it on a FAT32 formatted drive?
Topo
STAFF SERGEANT
So you had Windows working and it crashed or is this a new build and you trying to install Windows 10?
Also have you connected the keyboard to the top black USB 2.0 ports on the motherboard?
