Z390 A-PRO / 9700K Current/EDP Limit Throttling Problem
xqlusive
Hei guyz, hope u can help me.
Trying to OC 9700k (Kraken x62 cooling)/Z390 A-PRO/MSI RTX 2070 SUPER.
Parameters i use in BIOS:
CPU Core Voltage - 1,32 / Adaptive
CPU SA - 1,2
CPU IO - 1,25
CPU Ratio 46-47-48/ doesent matter (All cores).
Ratio fixed
Turbo boost off
Ring ratio = CPU Ratio -3
R. Offset (avx) -3
Load Line Mode 4
C-State disabled.
When i run Cinebench15,20 or 3DMark everything is ok, but when testing with Intel Extreme Tuning Utility  it shows Current/EDP Limit Throttling. If i disable AVX bench then it dissapears.
I tried to OC with Intel Performance Maximizer and using that i have 4,9 all cores and no throttling in Extreme Tuning Utility.
What could be the reason? or maybe i forgot to setup some parameter in BIOS?
Below HWinfo with x48 OC and without OC.
