Z490 A PRO - Stuck on CPU LED on EZ Debug after playing VR Games - NOT UPDATED
Hey!
Sorry for my english!
I recently have trouble booting my gaming rig after an intensive VR gaming session.
The computer just shut down by it self and then turned on/off several times. I decided to unplug my power cord wait for it to cool down and then trying power it on.
It started with no issues. Checked the temperature immediately on my cpu and it stood 80 celsius. Also checked the GPU temperature on 60 celsius.
So thought there were no problems i could find directly. So I tried booting SteamVR and try some VRigade 2. After 5min aprox. it shut down again and turning off/on.
After unplugging/plugging it again on the power cord the computer turns on and the fans are moving but it doesn't boot anymore.
Looking at the motherboard the CPU led was lit. Thought the CPU got to hot.
I boutght a new cpu and installed it but still doesn't boot and still are on CPU Led.
I started to think that the PSU itself is not giving the right power anymore because when trying to start with only the cpu 2 power cable it didn't start and after the cpu 1 power cable connected it started.
Here are my PC specs bellow:
MSI Z490-A-PRO
INTEL i5 10600K
MSI GTX1660 SUPER
CORSAIR VENGEANCE LPX 2x16 GB
PLEXGEAR PS-700M (700W)
Had a Cryorig C7 cooler for the cpu befor the shutdown so i bought the be quiet! Dark Rock 4
Samsung 870 EVO 1TB
Windows 10 Pro
Gaming Gear:
Valve Index
Logitech MX Keys
Razer Abyssus v2
Dell 27"
Your PSU is highly suspicious. It seems to be some kind of local product for Scandinavia, it's hard to find information on it or even the official website. But i can see from its specs that it an outdated, group-regulated design which is not suitable for a modern, 12V-dominant platform. It was introduced 11 years ago. If your specific PSU is also approaching anything near that age or even half that age, that would be another important reason to replace it. Because it's probably aged half to death by now.
Since you have a be quiet! cooler, maybe you want to get a PSU from them too, cause they're good. For your system, i would recommend a be quiet! Pure Power 11 (CM/FM), or even better, a Straight Power 11. 500-550W is more than enough with your current hardware. Here's some more info i posted about how to select a PSU.
Ok! Thank you for you quick support.
yes the PSU is old but it worked fine after booting up first time in 2020 when geting the new motherboard. Have been using this PSU over a year with no issues on lower gpu games.
But i understand that old PSU might not be compatible with new motherboard.
The problem with PSUs is, it is not a simple case of "on = works" and "off = doesn't work". It's a complex piece of electronics which transforms the 230V or 115V mains power into 12V, 5V and 3.3V for the PC to use (with nowadays almost all power being pulled over the 12V rail). There can be a number of things wrong with the quality of the output voltages, and for many of them, there has to be some load on the PSU.
The first problem with your PSU is in its internal design. When you see high Ampere numbers for the 3.3V/5V rails in the specifications / on the sticker, the rail distribution is completely outdated for a modern system. Because then it's using a so-called group-regulated design, with heavy emphasis on the minor rails. But when lots of power is pulled on the 12V rail, like all modern systems do, all the voltages might tank or the PSU might even shut off from overcurrent protection. The group-regulated design is cheaper and it was popular a decade ago and before, but nowadays it's just not suitable. It can't handle cross-load with the majority of power draw from 12V. But that's exactly what happens with modern hardware, graphics cards included. Here you can see an example of another such PSU causing trouble, https://forum-en.msi.com/index.php?threads/z370-a-pro-bios-time-up-to-5-min.345939/#post-2001312
The second problem of a PSU is aging, mainly of the capacitors. I don't know how much warranty they gave for your PSU model, but i doubt it's more than two or three years. Meaning, that was the timeframe they deemed comfortable for the quality of capacitors they used and their placement (how much they heat up, since that will shorten their lifespan). When capacitors age, they can't help supply clean power to the components anymore, and can't handle transient (sudden) loads or sustained full load very well. That's why the warranty is such a good indicator of PSU quality. If you have five or more years of warranty, you can be quite sure that the capacitors are not the cheapest quality, otherwise the manufacturer wouldn't be comfortable giving such a long warranty.
The issue with assessing the PSU's output quality, or to detect PSU aging: To properly test it, you'd have to put it on a programmable power source and power meter (CHROMA test station, to create exactly specified loads), and watch the PSU's outputs under load with an oscilloscope, because there's a lot of different parameters and specs it has to fulfill:
https://www.hardwareluxx.de/images/stories/galleries/reviews/nt-roundup-chroma-april12/chroma01.jpg
https://www.hardwareluxx.de/images/stories/galleries/reviews/nt-roundup-chroma-april12/chroma02.jpg
https://www.hardwareluxx.de/images/stories/galleries/reviews/nt-roundup-chroma-april12/chroma03.jpg
https://www.hardwareluxx.de/images/stories/galleries/reviews/nt-roundup-chroma-april12/chroma04.jpg
Should your PSU be at fault like i suspect it might be, then you're actually testing it as best you can at home, by creating the highest overall load you can: Putting both your CPU and graphics card under load, which an aging, cheap PSU can no longer handle, and either the PSU shuts off, or the mainboard does, because it detects something weird with the voltages and a protection circuit trips.
The only way you can reliably exclude it as the culprit at home is testing the same system with a different PSU. Problem stays the same -> wasn't the PSU, problem disappears -> was the PSU.
Since your PSU generally seems "not the best", i would advise you to outright buy a new PSU, not just for testing, but also because it's the foundation of your system and you should get a better one.
In this comment, i explained what to look for in a PSU: https://forum-en.msi.com/index.php?threads/need-help-with-rebuild.365522/#post-2072488
