Z490-A Pro Super Charger or not?
robin.dieks
So according to the manual my Z490-A Pro supports the Super Charger as a Dragon Center Feature.
However, the board does not have a red JUSB1 as i'm used to from my previous Z77a-GD65, also Super Charger does not appear to work at all.
Thereby the Super Charger.ini file does not appear to have the motherboard type (MS-7C75)
So does it or doesn't it support Super Charger and so which port(s) to use?
fatedust
FIRST LIEUTENANT
Try to connect any one of the front panel USB port after switching Super Charger on in Dragon Center?
robin.dieks
Doesn't change anything.
Used USBDeview to check power draw, keeps to 500mA eventhough both my iphone and ipad would be fast charge supported.
Interestingly the service itself appears to be running and is generating logs aswell.
Also in Dragon Center at the Super Charger app it just says "SUPER CHARGER was already running" no controls to switch on/off.
Super charger should apply to the front panel USB's. Control should work from Windows task menu not DC.
yashraj6789
Hey,
I am facing somewhat of a similar issue with the x570 gaming pro carbon motherboard. Can you please elaborate where exactly can I control it from the Windows task menu rather, how/what should I change there to fast charge my devices?
TIA!
fatedust
FIRST LIEUTENANT
X570 GAMING PRO CARBON WIFI does not support super charger function, I just checked the manual for you.
yashraj6789
How is that possible? It shows up in dragon center and I can download it and use it. It even shows "Super Charger was already running". O
fatedust
FIRST LIEUTENANT
Well..., I'm confused now. I checked the manual and didn't find super charger under the Dragon Center Features (see pic #1)
But I saw something related in pic #2. So maybe it do support this function. Just make sure the port is connected to JUSB1/ JUSB2.
Pic #1: Pic #2:
