I have noticed only after a few weeks but this is not good for cpu i think.
This has been noticed with an i7-11700K without overclocking @ stock clocks.
It concerns the VCCSA and VCCIO2 voltages, when left to auto like the board comes out of the box the voltages are way out of spec.
VCCSA at auto gives 1.597V , when setting it manually the red values start beyond 1.2 V , that is 0.4V overdriven.
VCCIO2 at auto gives 1.376V , when setting it manually the red values start beyond 1.15V , that is 0.2V overdriven.
Why does MSI do this ? It is good to degrade the cpu very fast which is not what anyone wants besides maybe Intel who would like extra sales.
When having them set at their correct values of 1.2V and 1.15V there is no negative effect,
in fact with the higher auto voltages the system was getting data corruption which has now ended by setting them manually to the max safe values.
This has to be addressed ASAP before CPU's all over get killed with these high out of spec auto voltages.
Other values at auto seem to be in spec, but maybe the cpu cores are getting also more than they actually need to run, this would require more testing which i'm not looking to do. Going up to over 1.4 Volts is not needed for running at stock speeds without overclocking either. The system could be way more power efficient than it is.
