I've been having problems (like many others) getting the on board DVI port to work. I've done some testing and here is what I've found.
My monitor is an ASUS VE247H.
A direct connection between the DVI port of the mainboard and my monitor results in no output. Monitor gives a "no signal" message. A single link or dual link DVI cable yields the same result. There is no difference between the two.
A DVI to HDMI adapter connected to the HDMI input of the monitor works.
A DVI to VGA adapter connected to the VGA input of the monitor works.
An HDMI to HDMI connection from mainboard to monitor also works.
Monitor worked with my previous PC connected via DVI. Monitor also works with Z68A-GD80 and a discrete card connected via DVI. That should rule out the monitor being the issue.
At this point I figured the DVI port was just faulty. I have already received a call from MSI, after discussing my DVI problems in a Newegg review, and was instructed to RMA the board back to Newegg for a replacement. Before taking everything apart, I decided to try the only other "monitor" available to me with a DVI input, my Samsung DLP TV (model#HLP4663WX/XAA). So I directly connected the mainboard to the TV (DVI to DVI), with a single link DVI cable and amazingly, that worked.
This leads me to believe there is definitely some issue with the way the BIOS handles communication to/from the monitor, and not just a faulty DVI socket.
Another observation I've made, the same monitor is detected differently depending on what interface is being used. For instance, when I connect via HDMI, the Intel Graphics and Media Control Panel shows my display as "Digital Television VE247".
If I connect with VGA, the display shows up as "Monitor VE247".
Hopefully this is of some use to MSI. We really need these port issues fixed.
