what file?As a side note, when using the forum flasher and mode 1, it would not accept the file.
Forum flasher defaults to looking for zip files, if you pick rar from the drop down it should accept the file just fine, if you don't use method 1 you won't get the ME flashed.Froggy Gremlin said:I was about to give up after I had reverted back to Sandy and ME7 again (reference link), but wasn't really all that happy with the v18.7 results. v18.8 or any of the Sandy Beta's were not performing as well as I thoughht they should. Gave this v19.2B1 Ivy Beta a chance. Glad I did!
https://forum-en.msi.com/index.php?topic=162713.0
As a side note, when using the forum flasher and mode 1, it would not accept the file. I had to unpack it and use mode 2. One thing that was missing doing it this way was probably the file that said VALCHECK wasn't included on the USB stick? Was it necessary it should have been? Putting it on the prepped USB stick and reflashing required? As the original vJ0 did, does this Beta also update the secondary chip?
The archive file. The tool would not accept the .rar file in Mode 1.Svet said:what file?
E7672IMSvJ21.rarSvet said:yes i guess, but which one?![]()
Yes.Svet said:the same hosted in this topic or?
v1.24hSvet said:what tool version you use?
"Extract BIOS file from BIOS archive, then use 2nd mode".Svet said:what message did you get?
Svet said:double check that you pointed to the right archive file and not something else
Yes, originally I did that and it wouldn't accept it.Svet said:no i mean when you point to mode1,
make sure that you gonna select the right archive file
