Z690-A Issue with GH50, GM50, GK30 Devices
howarthj15b802e5
My motherboard does not like it when I have all three devices plugged into certain USB ports. The headset ceases to function properly and I get the windows error "not enough usb controller resources". When I looked using USBView application all the ports are under a specific USB Hub. It is the column with the two blue USB ports (see attached picture). Is this expected behavior? All three devices are RGB so maybe they use a lot of power/resources?
Anyone else have this particular board & devices and it works fine for you? I am under warranty for my computer but I am hesitant to give it to them for a month.
Pro
BIOS is the newest version? If not, try that first.
SHALALA
FIRST LIEUTENANT
May I know which certain USB ports did you plug the devices?
And the port you connect to headset which is not working, try connecting other devices and see whether it's functional.
Please also reinstall USB driver~
badboy2k
its not going to be a power issue unless you have multiple devices on a single port as each of the Black can do 500ma (0.5A) and each Blue and red can do 900ma (0.9A) and non of them are above 500ma tops (would be mainly the Keyboard and if you set it to all White it may pull upto 500ma)
