sparkiiro
- Oct 8, 2024
Good afternoon everyone!
Not all the above happen at once, sometimes they don't happen at all. It's often though and it's daily that at least one of these, most commonly it's the first one and the sluggish one but recently the monitor issue has arisen.
I understand that these could be individual parts and I have a sinking feeling it's Windows self-sabotaging, because when it boots up from off, it's very fast to get to my login screen, very smooth.
I did some digging and found a reddit post recommending I change the PCI-e to Gen 3 and it worked beautifully for a few days, then reverted back to its old self very quickly. It's still on Gen 3 now.
I've attached my CPU-Z text report if that's helpful too. My knowledge really stops here, so please be nice to me!
Thanks!
- Thought I'd come here to see if I can shed some insight on this as this PC was a lot of money, a lot of savings and a replacement for my og Skylake build in 2015.
- CPU: Intel i-9 13900
- MB: Z970 EDGE Wifi DDR4
RAM: DDR4 32GB Corsair Vengeance - GPU: AMD Radeon RX 5600 XT
- Essentially, I've had some various issues with the PC that happen daily and force me to restart. I am hoping it's not the mb as that's the hardest thing to replace, but I thought I'd share and see what you think:
- - PC will not start up fully - Windows Explorer will not initiate, Wallpaper Engine won't start (this is a big red flag for me) - have to fully shut down and start up.
- - PC does not display on my main monitor, but my secondary monitor works fine. Each source on my monitor cycles. Have to restart to get it working.
- - PC is sluggish with little installed onto the system, running Win10 from a 1TB m.2 - restart works fine
- - Does not recognise two SATA drives plugged into the mainboard (contains all my old files, slowly moving over to m.2 storage when I have funds) - have to restart
- - Fancontrol often crashes and doesn't change fan speed on set up (I understand this is freeware and could be buggy)
- - If left to sleep, will not operate on waking, forced to restart.
- - Several USBs won't work.
- - Certain low-impact software (such as Clip Studio) will be laggy, worse than on my gen 6 Intel. High impact software is a gamble, Photoshop often lags severely, but its low-impact alternatives like Affinity also struggle.
- - Several software apps have reset their cache and preferences this week, without me doing anything. Adobe keeps signing out, Clip removed all recent files, I've been asked to confirm default applications for opening Jpegs? Strange.
Thanks!
