Z790 Tomahawk wifi max ethernet problem need urgent HELP.
gurhan.bayi15d102e8
A few days ago I purchased the following components and setup my pc. I came across some problems which I solved some and there are a few which I am stuck into. but the most frustrating is my network connection problem which makes me mad and really considering to return the motherboard back. My main problem is that eventhough it says connected it doesnt seem to communicate and need to disable and enable the connection. There is also an alternate version of problem where it says "action needed no internet" the solution is the same disable and enable the connection. I made a reasearch about the ethernet controller "Intel(R) Ethernet Controller (3) I225-V" and there are a lot of same issue problems seems like this controller is doomed. what i have done so far is as follows i have made some changes on the device which i added below which i created with intel system support utility.
Any help is welcome it makes me really mad. Thank you all in advance for your kind helps.
My configuration.
Processor: Intel Core i7 13700K
Memory Type 2x16GB Crucial CP16G56C46U5.C8B2
BIOS version A.10 dated: 09/13/2023
MB MAG Z790 TOMAHAWK MAX WIFI
Asus RTX 2060 OC
4Port PCI USB 3 card.
Samsung 980 pro m2. NVM.
Intel System Support Uility
- "Intel(R) Ethernet Controller (3) I225-V"
Availability:"Running or Full Power"
- "Caption":"Intel(R) Ethernet Controller (3) I225-V"
Link:"http://www.intel.com/content/www/us/en/search.html?keyword=Ethernet+Controller+(3)+I225+V"
CoInstallers:"Not Available"
Default IP Gateway:"192.168.1.1"
DHCP Enabled:"Yes"
DHCP Lease Expires:"10/29/1955 08:41 PM"
DHCP Lease Obtained:"11/16/2023 11:58 PM"
DHCP Server:"192.168.1.1"
Driver:"e2fn.sys"
Driver Date:"06/29/2023 12:00 AM"
Driver Path:"C:\Windows\system32\DriverStore\FileRepository\e2fn.inf_amd64_fcb868ac03f43b71\e2fn.sys"
Driver Provider:"Intel"
Driver Version:"2.1.3.15"
ETrackID:"Not Available"
Index:"0002"
INF:"oem7.inf"
INF Section:"I225.10.0.1..21390"
Install Date:"Not Available"
Installed:"Yes"
IP Address:"192.168.1.22;fe80::51bf:d58e:5b50:8190"
IP Subnet:"255.255.255.0;64"
Last Error Code:"Not Available"
Last Error Code Description:"Not Available"
Last Reset:"11/16/2023 11:55 PM"
MAC Address:"D8:43:AE:15:17:8B"
Manufacturer:"Intel"
Net Connection ID:"Ethernet"
NetCfgInstanceId:"{9D843A83-373B-42AD-A6A2-929E2B108494}"
NVM Version:"Not Available"
Part Number:"Not Available"
PNP Device ID:"PCI\VEN_8086&DEV_15F3&SUBSYS_7E251462&REV_03\D843AEFFFF15178B00"
Port:"Not Available"
Power Management (Low Power):"Active: Yes, Enable: Yes"
Power Management (Wake On LAN):"Active: Yes, Enable: No"
Power Management (Wake on Magic Packet):"Active: Yes, EnableWakeOnMagicPacketOnly: No"
Power Management Capabilities:"Not Available"
Power Management Supported:"No"
Product Type:"Intel(R) Ethernet Controller (3) I225-V"
Service Name:"e2fnexpress"
Status:"Enabled"
Type:"Ethernet 802.3"
- "Service Bindings"
Bridge Driver:
Client for Microsoft Networks:
File and Printer Sharing for Microsoft Networks:
Internet Protocol Version 4 (TCP/IPv4):
Internet Protocol Version 6 (TCP/IPv6):
Link-Layer Topology Discovery Mapper I/O Driver:
Link-Layer Topology Discovery Responder:
Microsoft LLDP Protocol Driver:
QoS Packet Scheduler:
VMware Bridge Protocol:
- "Settings"
*FlowControl:Flow Control:"Rx & Tx Enabled (3)"
*IdleRestriction:Idle power down restriction:"Disabled (0)"
*InterruptModeration:Interrupt Moderation:"Enabled (1)"
*IPChecksumOffloadIPv4:IPv4 Checksum Offload:"Rx & Tx Enabled (3)"
*JumboPacket:Jumbo Packet:"Disabled (1514)"
*LsoV2IPv4:Large Send Offload V2 (IPv4):"Enabled (1)"
*LsoV2IPv6:Large Send Offload V2 (IPv6):"Enabled (1)"
*PMARPOffload:ARP Offload:"Enabled (1)"
*PMNSOffload:NS Offload:"Enabled (1)"
*PriorityVLANTag:packet Priority & VLAN:"Packet Priority & VLAN Enabled (3)"
*SpeedDuplex:Speed & Duplex:"Auto Negotiation (0)"
*TCPChecksumOffloadIPv4:TCP Checksum Offload (IPv4):"Disabled (0)"
*TCPChecksumOffloadIPv6:TCP Checksum Offload (IPv6):"Disabled (0)"
*UDPChecksumOffloadIPv4:UDP Checksum Offload (IPv4):"Disabled (0)"
*UDPChecksumOffloadIPv6:UDP Checksum Offload (IPv6):"Disabled (0)"
*WakeOnMagicPacket:Wake on Magic Packet:"Disabled (0)"
*WakeOnPattern:Wake on Pattern Match:"Disabled (0)"
ITR:Interrupt Moderation Rate:"Low (64)"
WakeOnMagicPacketFromS5:Wake On Magic Packet From S5:"Disabled (0)"
Hi wroger,
I have read your post and made a research as well in my native language and this can be the culprit. In 15-20 days my subscription reneval data will come and will change the router as well to a Zte H3600 Wifi6 . And then i can see what will happen and also will share the result with you as well. I would like to thank you very much for your kind help.
Kindest Regards.
@gurhan.bayi15d102e8 You're welcome. Always glad to help.
I would return the board (unless you can live with using another extra network adapter). There is no one that can verify I225 issues as being fixed. I226 is the solution.
