z97 mpower max ac
tno.rappelz
I have problem with wifi adapter in z97 mpower max ac
the problem is the disappearance wifi from my computer
I can't find wireless in network and sharing center and in device manage
i tried network troubleshooting and he said plug an ethernet cable into this computer!
(sorry for my bad English :D)
If you fixed it with the screw underneath the board unscrew it. Try reseating it and check if there are bent pins on the board. If not retry with the adapter card not screwed to the board and check if it is detected.
