Author Topic: P965 Neo sound problem  (Read 2483 times)
StihoklepacTopic starter
« on: 28-September-06, 23:22:11 »
Well i tried with 3 msi motherboards and the problem is same.
After instalation of windows xp sp1 i instaled sound drivers and they worked fine,but
when i install sp2 or when i install slipstreamd sp2 and only sound drivers there is no sound on green output port.
I tried 5 diferent drivers,million settings everything but i could not resolve problem  :wall:
Windows detects playing sound in graphic equiliser on media player or winamp but there is no sound on either conector.
Any ideas ....i tried with latest msi and realtek drivers,i flashed bios to last version,i even changed procesor and memory sticks but no results...
nomadph
« Reply #1 on: 29-September-06, 02:07:24 »
check the realtek drivers from this topic:
https://forum-en.msi.com/index.php?topic=101280.0
« Reply #2 on: 29-September-06, 07:55:11 »
I tried and still no results.
nomadph
« Reply #3 on: 29-September-06, 08:06:05 »
have you verified if it's your speaker that's broken?
also, the problem occured when you installed sp2 right? i have sp2 on my machine too, but don't have that problem..hmm...if it's not too late, try repairing/reinstalling windows?
« Reply #4 on: 29-September-06, 13:06:45 »
they are working just fine,also headphones i tried a dozen of them ....also i found same problem on
asus p5w dh deluxe mb same sound card and same problem still no solution
Me27
  • SERGEANT
« Reply #5 on: 14-November-06, 20:40:35 »
I also have the same problem. Does anyone know how to fix this?
NovJoe
« Reply #6 on: 15-November-06, 12:29:10 »
Just a side note. If you have front audio panel jumpered, try setting the jumpers back to the original settings and see if it helps.
MSI HQ Forum USB flasher
Me27
  • SERGEANT
« Reply #7 on: 15-November-06, 13:22:37 »
I have tried putting a jumper on 5-6 and 9-10.
Its strange that MSI does not talk about this in the manual or supply jumpers.
