Author Topic: Geforce3 TI200 problem  (Read 1546 times)
Drackwolf
« on: 06-January-03, 15:55:50 »
Im not sure whats causing this. All over my screen, in both Win98 and XP, Im getting thin transparent flickering lines all the way down the screen. It gets worse if I turn the refresh up higher, or play a game.
Ive also had problems with Unreal Tournament 2003 freezing every few seconds in resolutions higher then 640x480, but that may be unrelated.
Ive got a Soyo Dragon motherboard, with an Athlon XP 1800+, 256 megs of ram, 300watt power supply.
Richard
  • nForce & GeForce Guru
« Reply #1 on: 07-January-03, 16:12:47 »
  • Best Answer
  • Drackwolf,
    Try your comp with another monitor and see if it is the vid card or the monitor.  (I do not mean buy another monitor, just hook it up t a friends monitor if you do not have another one around.)
    Good Luck,
    Richard
    Richard J. Gentil, Pres.
    Custom Computers of Naples, Inc.
    LANPARTY nF4 SLI-DR
    Athlon64 3700+ Sandy
    (o/c'd 2.8Ghz)
    Zalman CNPS9500LED
    2-1Gb Mushkin Extreme PC-4000 (Slots 2 & 4)
    (o/c'd 510Mhz)
    2 x MSI NX6800GT-T2D256 (o/c'd Stock)
    X-Mystique 7.1 GOLD - Dolby Digital Live
    2-WD Raptors Raid 0
    (16k Stripe)
    NEC 16 Dual Layer DVD+/-RW
    Logitech Z-680 500W Dolby Digital DTS THX 5.1
    Logitech MX1000 Laser Mouse
    Saitek Eclipse Keyboard
    Drackwolf
    « Reply #2 on: 09-January-03, 14:06:44 »
    Update.
    When I swap out to my Geforce2MX, the problem is gone, and everything runs ok. My PSU is a 300watt, 170 combined I believe, but Im not sure thats the problem
    Recently, games have started freezing sporadicly in some cases, and just going back to normal a few seconds later, and that doesent occur with the Geforce. The problem with the lines has gotten MUCH worse, theyve become much more noticable on the desktop. If it was a problem with power, wouldent the overall problem stay consistent?
    Chris Morgan
    « Reply #3 on: 09-January-03, 14:25:47 »
    Drackwolf
    Just an idea try your video card in a friends machine to see if the card is faulty.
    Also try setting the voltages to the AGP slot manually they should be around 2.6 / 2.7 Volts.
    Hope it helps
