Author Topic: c&c generals/zero hour not starting  (Read 3107 times)
Noizer
  • Cyclone
  • :censored: lol pwnd keke???
« on: 28-November-06, 21:25:52 »
the game freezes when the first generals window comes up and in task manager it says that it is not responding >:( :angryfire:
i have formatted my computer and installed the games several times and it still dosent work :nono:
any ideas what wrong?????????
Ex Forum Mod
  • Hawk
Re: c&c generals/zero hour not starting
« Reply #1 on: 28-November-06, 21:32:15 »
 What OS are you using and does it play the orignal C&C Generals?
Noizer
  • Cyclone
« Reply #2 on: 28-November-06, 22:27:49 »
i have win xp pro.
its an original copy of generals.
Ex Forum Mod
  • Hawk
« Reply #3 on: 28-November-06, 23:03:16 »
 Have you read the "Read Me" file for C&C Gen. to make sure you have your PC setup properly to run the game? It tells you what you should do before playing the game.
  • T9246ED, Бивша комета
  • Administrator
    • MSI BIOS/EC-FW Mods
« Reply #4 on: 28-November-06, 23:31:16 »
right click on executable shortcut, click properties, select compatibility tab, tick "run this program in compatibility mode for:" and select "Windows 2000", "apply" and "OK". re-run game.
Stu
  • Hawk
  • Birmingham, UK
    • StuOnline.co.uk
« Reply #5 on: 28-November-06, 23:33:50 »
Noizer,
do you have any other problems with your system, or with running any other 3D applications, or is it just this particular game that is causing you a problem?
the more background info we have, the better the answers will be
Ex Forum Mod
  • Hawk
« Reply #6 on: 29-November-06, 00:06:57 »
 I just installed the game on my PC to see if any problems and it installed and played OK so it should not be an XP compatability problem. I also had the game on here when I 1'st built this PC with W2K with no probs so you might have other issues wth your PC not related to the game.
  • Administrator
« Reply #7 on: 29-November-06, 00:14:08 »
install latest game patch too: ftp://ftp.ea.com/pub/eapacific/generals/generalszh/DownloadablePatches/GeneralsZH-104-english.exe
navigate to "my documents" and delete folder "Command and Conquer Generals Zero Hour Data\"
re-run game. at 1st run it take some time to reconfigure. look like hang/lockup at 1st initial screen and nothing responded for around 1-2 minutes. then everythink goes smooth. that happend at 1st run only, every other future running is load around in sec.
Noizer
  • Cyclone
« Reply #8 on: 29-November-06, 16:34:59 »
Thx BOSSKILLER :worship:
it works now ;D
  • Administrator
« Reply #9 on: 29-November-06, 16:45:19 »
it works now ;D
you are welcome mate :yes:   :hat tip: happy game  :biggthumbsup:
