Author Topic: MSI P965 and SpeedFan's fan speed control  (Read 7993 times)
EiccaTopic starter
« on: 07-January-07, 20:18:03 »
Is there any possibility that i could get that SpeedFan's fan speed control work on my mother board? =)
Jack
  • Ex Forum moderator
« Reply #1 on: 07-January-07, 20:28:16 »
I read a lot of Threads about this question and it seem that Speedfan does not (yet) support the 965 Platinum.
Send a report to speedfan developer using the "send report"-option of the program (info tab)...
Alfredo Milani Comparetti is working on a new version and there is a good chance, that it will support newer chipsets...
prc
« Reply #2 on: 07-January-07, 21:45:52 »
You can control your FAN speed (MSI 965 Neo-f, not sure about platinum), you just cant read the RPM.
At least in December or so you had to use beta version of speedfan (you must register to download it, no spam sent to my email after registering).
More on this thread, Im getting bored of writing about this issue :)
https://forum-en.msi.com/index.php?topic=103444.0
BlueKnight
  • STAFF SERGEANT
« Reply #3 on: 08-January-07, 20:17:14 »
I have MSI P965 NEO ... sorry but you getting bored of write about this...but like other people that i know, whit Speedfan 4.32Beta .... and the only thing we can do is to read rpm and not controll fan.
Why this difference? :P
CM Stacker - Intel C2D E6400 @ 3.0GHz (8x375) + TT Big Typhoon - 2x512MB S3+ 800 @ 375MHz 4-6-6-20
MSI P965 Neo (v1.6) - PowerColor Radeon X1800XT 512MB @ 702/801MHz + Zalman VF900-Cu
Samsung SP120 200GB SATA2 - CM Real Power 450W - Samsung 997DF 19" CRT - Masteriz SATA INCOMING
EiccaTopic starter
« Reply #4 on: 08-January-07, 20:31:59 »
Well, is there ANY possibility that i could control my fan speeds by software?
Streifenkarl
  • MAJOR
« Reply #5 on: 08-January-07, 22:35:50 »
What software can I use to read
fan speed
voltage on all rails
system temp
CPU temp
with the Neo-F? And I'm talking about one software for all! Why dont the Intel TAT and DualCore Center (MSI's own freakin software!!!) work on the Neo-F!   :angryfire:
MSI 865PE Neo2 FIS2R
BlueKnight
  • STAFF SERGEANT
« Reply #6 on: 09-January-07, 00:28:13 »
fan speed
system temp
CPU temp
Or Everest or Speedfan...
Streifenkarl
  • MAJOR
« Reply #7 on: 09-January-07, 01:09:10 »
Speedfan doesnt work. And the new Everest version has to be purchased in order to get all readings.
Maesus
  • in Penang, Malaysia
« Reply #8 on: 09-January-07, 12:58:27 »
guess we have to stay with dualcore center ?! :undecided: .. the reason is the fan control chip is MSI proprietary chip... unless somebody provide Speedfan author to know how and where to access the registers...
Please read the ==>MOAN Guide<==
Maesus
My PC:
Now using : IBM Thinkpad T60p
Core 2 Duo recipe
E6600 2.66Ghz with GB Rocket Cooler Pro : MSI 975X Platinum PUE BIOS 7.6 : DDR2-667 2x1GB + DDR2-800 2x1GB : MSI 8800 Ultra : 80GB WD Caviar SE : Maxtor 250GB SATA : LiteOn LH-20A1S DVD writer + Samsung SH-W162C DVD writer : MSI Theater 550 Pro : LOGITECH Z-680 : DELL E228WFP 22" LCD : PowerLogic 500W PSU with +12V1&+12V2 @ 32A total
BlueKnight
  • STAFF SERGEANT
« Reply #9 on: 09-January-07, 15:26:57 »
How can Speedfan don't work?
You have 4.32 Beta? And your bios?
Second, this is my first MSI motherboard, but i don't think that MSI product a proper chip for fan...i think it use Winbond chip..
EiccaTopic starter
« Reply #10 on: 09-January-07, 17:10:46 »
So there is no possibility that i could control my fans by software?
BlueKnight
  • STAFF SERGEANT
« Reply #11 on: 09-January-07, 18:13:55 »
prc say that you can...but he don't write how...whit speedfan i can't...he say that it's possible...bha...write him a PM
prc
« Reply #12 on: 10-January-07, 20:09:19 »
Oh... rly dunno :). I got my speedfan to control fan speed, using core1 and core2 temperatures for controlling. Fan obviously speeds up (with speedfan's % values when i run e.g pifast), changing fan speed % setting manually causes fan to change speed, or at least so my eyes and ears seems to note it.
If you want instructions for setupping, I have to admit that this is actually first time I'm able do it with my mobo, so I just followed the pictures found from SpeedFan help/quide. Only reason I'm running with stock cooler is that I have been too lazy to get new hoses for my watercooler.
When I installed SpeedFan I first got to see FAN speed for a short while. While setting up speedfan's settings for fancontrol the FAN speed value dropped to 0. After that it has been dead except for once it worked for like 5 seconds or so.
My version seems to be SpeedFan 4.32 Beta 8. I'm currently running BIOS 1.6B13 on WinXP sp2, with some drivers which version number I dunno. Old Bios because I haven't had time and/or interest to flash 1.6B15 as I should again debug with my 3 SCSI cards and write more $hit to support, which cant help me I'm afraid.
Seems to work, when I drop core target temperature below idle temps, the Fan slowly speeds to 100%, and back to 25% when I put it back to normal threshold.
Wonder if theres sum tool for Windows to take live screen capture video to prove it  :think:
I'll try to remember tomorrow to check the forums.
prc
« Reply #13 on: 10-January-07, 20:20:56 »
Sry didn't mean it like that. I was trying to say that I see quite much same topics, so it feels like copy machine to write same stuff every time, so linking to old topic :)
For example u can weekly see new topic "p965 neo not booting from cd-rom", always same problem with that stupid Jmicron & mobo BIOS illogical operation.
Checking forums weekly if I should spot someone having samekind of PCI-line problems I have.
prc
« Reply #14 on: 11-January-07, 14:19:08 »
Did some thermal throttling tests today, pics @ www.mbnet.fi/~prc/temp/
Thats what I see from speedFan, changing fanspeed % from 0 -> 100 causes fan to keep louder voice. So seems it works. Tho RPM is shown 0.
Except at this picture the fan speed is 0, as I had to remove my fan powerconnector to be able to get temps over 80C for thermal throttle to start.
BlueKnight
  • STAFF SERGEANT
« Reply #15 on: 11-January-07, 16:51:59 »
To see speed of fan you should set the divider on 8.
Try if you can see now rpm of fan?
Bye
prc
« Reply #16 on: 11-January-07, 18:05:32 »
Bye
 :lol_anim:
Yep, now I see the fanSpeed, so at least speedFan 4.32 Beta 8 is able to monitor & control the fan speeds. Setting power to 0% results 1060RPM, @ 100% its ~2000RPM.
prc
« Reply #17 on: 11-January-07, 20:37:39 »
Got an email today asking for setting up speedFan. Made a guide that alt east worked for me. https://forum-en.msi.com/index.php?topic=104408.0
