Pages: [1] 2 3  All   Go Down
Author Topic: OCUBA - Overclocking Utilities and Benchmarking Applications  (Read 172594 times)
AaronTopic starter
  • GENERAL
  • BOOST!
Always remember the risks of overclocking. If you damage something it's no one's fault, but yours. Overclocking components beyond stock specifications creates more heat; BE SURE to make it absolutely certain you have sufficient cooling to address the speeds your running at.
MSI (Micro-star International), this forum, or any of it's members will NOT be liable if you cause any damage.
Neither is any support provided for these programs.
"Don't cry if you blow stuff up."
ALWAYS remember the risks!
 :oc:
Layout:
Click app title to go to info/homepage.
Download button to download app.
System Tools:
ClockGen
ClockGen is an program dedicated to overclocking. Its main purpose is to change the system clocks on the fly : FSB (Front Side Bus) and GSB (Graphic Side Bus). ClockGen also provides some functions that allow you to improve and monitor your overclock.
Download
CPU-Z
CPU-Z is a freeware that gathers information on some of the main devices of your system. On the right side select whatever file you wish to download
Download
Intel Burn Test
Intel Burn Test is a very demanding stress test on the cpu and memory. If your computer completes a maximum burn test, you can be fairly confident that it is stable.
GPU-Z
CPU-Z for your GPU!
Download
NVIDIA System Tools
nTune for your whole NVIDIA-based machine.
Download
Real Temp
Real Temp is designed to read the 45nm "Penryn" (Yorkfield/Wolfdale) Core 2 processors correctly. Look at the homepage for a setup guide and tutorial.
Download
CoreTemp
Core Temp is a compact, no fuss, small footprint program to monitor CPU temperature.
The uniqueness of it is that it shows the temperature of each individual core in a each processor in your system! You can see in real time how the CPU temperature varies when you load your CPU.
Download
Speed Fan
If you need a tool that can change your computer's fan speeds, read the temperatures of your motherboard and your hard disk, read voltages and fan speeds and check the status of your hard disk using S.M.A.R.T. or SCSI attributes, then you came to the right place. SpeedFan is the software to go. It is fully configurable and you can create custom events to handle every situation in an automated way. SpeedFan works under Windows 9x, ME, NT, 2000, 2003, XP and Vista. SpeedFan works fine on Vista 64 bit too. The relevant driver is fully digitally signed.
Download
EVEREST Ultimate Edition
EVEREST Ultimate Edition is an industry leading system diagnostics and benchmarking solution for enthusiasts PC users, based on the award-winning EVEREST Technology. During system optimizations and tweaking it provides essential system and overclock information, advanced hardware monitoring and diagnostics capabilities to check the effects of the applied settings. CPU, FPU and memory benchmarks are available to measure the actual system performance and compare it to previous states or other systems. Furthermore, complete software, operating system and security information makes EVEREST Ultimate Edition a comprehensive system diagnostics tool that offers a total of 100 pages of information about your PC.
Download
CoreMeter
CoreTemp... With a graph!
Download
HWMonitor
HWMonitor is a hardware monitoring program that reads PC systems main health sensors : voltages, temperatures, fans speed.
Download
NextSensor
No description yet.
Download
AMD overclocking:
AMD OverDrive
AMD's overclocking tool for 790FX and Phenom. Allows core frequencies to be altered independantly.
Download
A64tweaker
Memory timings tweaker for Athlon 64 users.
Download
A64MemFreq
Memory divider assistant.
Download
Central Brain Identifier
Program similar to CPU-Z.
Download
A64Info
Another memory controller tool.
Download (v.05)
Download (v.062 BETA)
Intel overclocking:
MemSet
MemSet is a memory tweaker for:
-Intel 815 845 855 865 875 915 925 945 946 955 965 & 975.
-AMD A64 ddr&ddr2.
-nVidia NForce2, NForce 650i & 680i.
-VIA KT266/333/400/600.
Download
SysTool
Gives a read out of the current northbridge strap.
Download
SiSoftSandra XI Lite
Gives a read out of the current northbridge clock.
Download
NBCCCalc
Simple tool to calculate the northbridge clock at different settings.
Download
Thaiphoon Burner
Tool for reflashing and altering SPD values.
Download
VGA Card Overclocking:
>>How to use MSI Afterburner<<
RivaTuner
RivaTuner is a complete powerful tweaking environment, providing you everything you may need to tune NVIDIA GPU based display adapters. The widest driver-level Direct3D / OpenGL and system tuning options, flexible profiling system allowing to make custom settings on per-application basis, both driver-level and low-level hardware access modes, unique diagnostic and realtime hardware monitoring features and exclusive power user oriented tools like built-in registry editor and patch script engine make RivaTuner's feature set absolutely unmatched.
RivaTuner supports all NVIDIA display adapters starting from Riva TNT family up to the latest GeForce 7 series and widest range of NVIDIA drivers starting from the oldest Detonator 2.08 up to the newest ForceWare drivers family.
Download
ATI Tool
ATITool is an overclocking utility designed for ATI and nVidia video cards. Design target is to write a light-weight application for the enthusiast - so no questionable registry tweaks. Sorry.
Download
ATI Tray Tools
ATI Tray Tools is a Full Featured Radeon Tweaker that can be found in the windows tray which then allows instant access to options and settings.
Download
nVidia Timmings
No description yet.
Download
AMD GPU Tool
This will overclock your AMD VGA card.
Download
NiBiTor v4.0
NVIDIA BIOS Editor
Download
Video Memory Stess Test
Stresses VGA card memory.
Download
nVHardPage SE
No description yet.
Download
nVidia Tray Tools
No description yet.
Download
Stability Testing:
Prime95
System stressing utility.
Tips:
Password is 9876. (Allows priority changing)
To run 2 instances of Prime95: For e.g open Run. Type "C:\Program Files\Prime95\Prime95.exe" -A1 (speech marks are required)
Download
BETA Prime95 that automatically sets required threads. (Handy for quad core users!) Download
MemTest86
Memory failure detection tool.
Download (Bootable ISO)
Download (.exe for USB Key/Drive/Stick)
IntelBurnTest
Simple command line based program to simplify the use of Intel's Linpack application.
Download
SuperPI
CPU stressing utility.
Download
Milliseconds Mod
Intel Thermal Analysis Tool
Intel's TAT can utilize an Intel CPU beyond any other app.
Download
SP2004 Orthos Edition
Dual core and memory stress testing.
Download
SuperPrime
New benchmark based on Prime95 code.
Download
wPrime
wPrime is a benchmarking application designed to use a highly multithreaded approach to calculating the square-roots of large amounts of numbers.
Download
Other
CrystalCPUID
Amazing tool. Many, many options to use and choose from. (Intel & AMD)
Download
RMClock
RightMark CPU Clock Utility (RMClock) is a small GUI application designed for real-time CPU frequency, throttling and load level monitoring and on-the-fly adjustment of the CPU performance level on supported CPU models via processor's power management model-specific registers (MSRs). In automatic management mode it continuously monitors the CPU usage level and dynamically adjusts the CPU frequency, throttle and/or voltage level as needed, realizing the "Performance on Demand" concept.
Download (.RAR)
MemTest for Windows
Same old MemTest app.
Download
OCCT Perestroïka
Download
S&M
No description yet.
Download
DPC Latency Checker
Checks latency, show safe, moderate and dangerous values. Check page for more detail.
Download
Ah yes... We can't forget to see how much of a change your overclock did now can we...
BENCHMARKING! ;D
Crysis Benchmark Tool
The tool provides a robust front-end to benchmark Crysis. It provides the ability to queue up many runs and will provide detailed results for each test as well as an overall summary with accurate averages. The first and foremost goals were simplicity and reliability in the tool and in the benchmark scores. Works with retail and demo.
Download
FRAPS
Video and CPU benchmarking Utility
Download
3DMark06
The legendary benchmark from FutureMark.
Download (Select mirror)
Nuclearus Multi-Core 2.0
The program Nuclearus Multi Core wrote to test speed of computer system (CPU-CHIP-RAM) and comparison with other computer system. You can use it to tuning, testing and benchmarking your system.
Download
Sciencemark 2.0 FINAL
No description yet.
Download
Toast
No description yet.
Lightsmark
A new 3D benchmark focusing on lighting effects and performance, dubbed Lightsmark, has been released for free by Czech software author Stepan Hrbek. This OpenGL 2.0 optimized test runs a flyby scene featuring realtime global illumination, color bleeding, penumbra shadows and displays the average FPS as an end result.
Download
Smart FPS
SmartFPS.com is a free software to benchmark latest videocards and processors by real world games like Crysis, Call Of Duty 2, Battlefield 2, Serious Sam 2, Call Of Juarez (full version), Quake 4, Prey and The Chronicles of Rid:censored:: EFBB.
Download
Cinebench R10
MAXON CINEBENCH runs several tests on your computer to measure the performance of the main processor and the graphics card under real world circumstances..
Download
Rightmark Memory Analyzer
Tip is in the name.
Download
ShaderMark
No description yet.
Download
AquaMark 3
No description yet.
Download
3DMark05
Another Futuremark benchmark.
Download
OpenGL Fur Rendering Benchmark
This benchmark requires a NVIDIA GeForce 5/6/7/8 (and higher) or an AMD/ATI Radeon 9600 (and higher) graphics card with the latest graphics drivers.
The startup interface allows you to tweak the benchmark features such as:
    * Benchmark mode or stability test mode (for overclockers)
    * Fullscreen or windowed for each type of run mode
    * Window size selection (standard or custom)
    * MSAA samples selection
    * Benchmarking parameters: time based or frames based
Download
MSI 990FXA GD80: versions of Control Center and Click Bios II that allow oc
>>Control Center<<
>>Click Bios II<<
Post a submition, I'll gladly add it to the list.
Refrain from having to solve most of your problems by not creating them in the first place.
DDR3 Memory Standards: Blurry Lines
Integrated Memory Controllers (IMC)
Intel EIST and Processor C-states
Overclock Database 2.0
Quadrifoglio Verde
  • MAJOR
  • The liver is evil...it deserves to be punished!
For stability testing:
- Orthos (dual core & memory stress testing)
- Prime95 (single core & memory stress testing)
- Super_Pi (Pi calculations, mainly cpu testing)
For AMD overclocking:
- A64MemFreq (Memory divider helper)
- A64Tweaker (Windows tool for lots of memory adjustments, reserved values etc.)
Use at your own risk of course... :hypocrite:
Desktop
MSI 790FX-GD70 / AMD Phenom II X4 965 Black Edition / Scythe Ninja / 2 x 4 GB Patriot DDR3-1600 / HIS Radeon HD 5770 1 GB IceQ 5 / Lian Li V1000 Plus II / Seasonic M12 II 520 / Samsung SH-S182D / 2 x Intel X25-M Postville 160 GB / 2 x Seagate Momentus 7200.4 500 GB / Enermax Aurora Premium (black) / Logitech MX518 / Logitech Z-10 / Eizo S2431WH-BK (landscape) + Eizo S2201WH-BK (portrait)
HTPC
MSI 785GME65 / AMD Athlon II X4 600e / 2 x 2 GB OCZ DDR3-1333 / Antec NSK1380 / 2 x Seagate Barracuda 7200.11 1 TB / Intel X25-M Postville 80 GB / LG Blu-Ray
DryHeat
  • FIRST LIEUTENANT
  • Phoenix, AZ - USA
For Intel:
Memset 3.0 - Allows you to adjust memory timings while in Windows. Works great when a BIOS forces 4-5-6-12 and you want 4-4-4-12.
- Antec P180 Case
- Asus/Pegatron Benicia G33 Express Mobo (ripped from HP m9300t)
- Intel Core 2 Quad Q9450
- Arctic Freezer 7 Pro
- 3GB Corsair XMS2 (2x1GB) (2 x 512MB) CAS5 @ 5-5-5-18 (1:1 Ratio - 1.8V) 800 MHz
- EVGA 9600GT 512MB
- SATA DVD/CD Writer
- 2x Seagate 7200.10 320GB
- 1x WD 500GB SATA II
- Corsair 750W PSU (+3.3V@30A,+5V@28A,+12V@60A,12V@0.8A,+5VSB@3.0A)
- HP w2207 Monitor
Exo
  • MAJOR
For A64: Central brain identifier - CpuZ like program wich is more uptodate ATM, as cpuZ has trouble detecting the right info from some 65nm A64's
( http://fileforum.betanews.com/detail/Central_Brain_Identifier/1050948388/1 )
For both c2d and A64: Coretemeter - CoreTemp like temperature readout using internal sensors, but with a graph so you can take a look at temperature history better
( http://www.softpedia.com/get/System/System-Info/Coretemeter.shtml )
AaronTopic starter
  • GENERAL
  • BOOST!
All added guys. Thanks :biggthumbsup:
  • T9246ED
  • Administrator
we can made later topic sticky, when the list of suggestions is full and no other suggestion posted.
aicjofs
  • MAJOR
  • Pop the Top!!
You didn't add DryHeat's suggestion.  Memset is a must have on this list.
Download link in this thread.
http://www.xtremesystems.org/forums/showthread.php?t=92190&highlight=memset
Also a nifty beta Prime95 for testing dual core and quad core that automatically spawns the right amount of threads. Best for quadcore IMO.
http://www.mersenneforum.org/showthread.php?t=6572
Another great tool that development seemed to have stopped, is A64tool, it was meant to be an all in one(coretemp, a64 tweaker, clockgen) but got stuck in beta, it's still very useful anyway, has a built in calculator for figuring out your overclock settings.  Read here
http://www.xtremesystems.org/forums/showthread.php?t=96678&highlight=a64info
Asus Maximus Formula(Rampage mod)
Q6600 (8x458) @ 3666Mhz 1.5V
2x2GB Gskill PC8000 5-5-3-13 @ 550Mhz (1100 DDR) 2.1V
EVGA 8800 GTs(700/1000)
2x640 GB Western Digital in RAID 0
NEC-3500 DVD, LiteOn LTD-163
X-FI extreme music
PC Power and Cooling 610W 3.3v - 24a 5v - 30a 12v - 49a
Dell e207FPW 20.1" Widescreen LCD
Watercooling: Dtek Fuzion, Iwaki MD-20, Thermochill PA120.3, 4 Yate Loon D12SM-12
AaronTopic starter
  • GENERAL
  • BOOST!
I did add DryHeat's suggestion of MemTest 3.0. But the current version of the app is 3.3
I'll add the Prime95 BETA and A64Tool shortly. :biggthumbsup:
Thanks for the suggestions aicjofs.
aicjofs
  • MAJOR
  • Pop the Top!!
Memset not Memtest.  It's like A64 tweaker but for Intel chipsets.
Hehe X-((
X-FI extreme music
DryHeat
  • FIRST LIEUTENANT
  • Phoenix, AZ - USA
Hehe X-((
wOOt!   :agrees:
- Antec P180 Case
- EVGA 9600GT 512MB
- HP w2207 Monitor
AaronTopic starter
  • GENERAL
  • BOOST!
Sheesh. Wrong again :wall:
My bad guys  :lol_anim:
aicjofs
  • MAJOR
  • Pop the Top!!
Looks good Yuri, good idea.   :biggthumbsup:
I was looking over my "tweak" folder on the hard drive, looks like we got most of the current stuff.
Only other 2 I had that are useful to me for overclocking and probably would be in an "other/misc" section of your list.
CrystalCPUID
http://crystalmark.info/software/CrystalCPUID/index-e.html
RMClock
http://cpu.rightmark.org/products/rmclock.shtml
These have 2 functions for me.
1) Most people say to disable CnQ or SpeedStep(EIST) for overclocking.  The real reason behind that is your multi/voltage transitions are hardcoded and so the system could change PStates to something making your system unstable.  If however you can control the multi/voltage yourself to something that is stable and you aren't a user that has constant 100% CPU usage(F@H for example), you can get the benefits of lower power and heat while you are just surfing/checking email.  These programs allow you to customize those power management features.  I have used them on heavily overclocked systems for years with no stability issues.
2.) If your motherboard has a simple BIOS without features for some CPU settings, you can write CPU MSR's or toggle features that you want or don't want.
X-FI extreme music
AaronTopic starter
  • GENERAL
  • BOOST!
I'm quite familiar with CrystalCPUID.
Shall be adding those aicjofs :biggthumbsup:
BTW, names Aaron. Got the Yuri bit from Command & Conquer ;-))
BG84
so we guess youre playing tiberian sun now?
its a good game, but company of heroes is better....
AaronTopic starter
  • GENERAL
  • BOOST!
No that's too old. I got it from Red Alert 2 Yuri's Revenge. But in all honesty I'd rather play Command & Conquer 3, which just arrived today BTW ;D
BG84
stupid me, its tiberuim wars im talking about, the 3 yes.
AaronTopic starter
  • GENERAL
  • BOOST!
Yep I'd much rather be playing Tiberium Wars ;-))
Have you played it BTW? C&C3?
Ex Forum User
  • MAJOR
Dont forget FRAPS for video and Benchmarking, http://www.fraps.com/
BG84
yes i do have it, its great, but like i mentionned, i like company of heroes 10 times better
AaronTopic starter
  • GENERAL
  • BOOST!
Well BG84 I did play the demo a couple of times, and also waited forever for it to download. But it's still not my favorite.
C&C3 and Supreme Commander all the way! :agrees:
DOK, I shall be adding your suggestion shortly, thanks. :biggthumbsup: Added!
Quadrifoglio Verde
  • MAJOR
Some additions for Intel overclocking especially:
Systool - will give you the read out of the current Northbridge strap
SiSoft Sandra Lite XI - will give you the read out of the current Northbridge Core Clock
NBCCCalc - simple VB tool to calculate your Northbridge Core Clock at given settings
Desktop
HTPC
AaronTopic starter
  • GENERAL
  • BOOST!
Thanks for giving me the download links guys, makes my job much easier :)
gbjbany
The folding forum recommended stress testing with StressCpu2.
Here's a link  http://www.gromacs.org/component/option,com_docman/task,doc_download/gid,80/Itemid,26/
Intel C2D E6600 (OC 333)
MSI P965 Platinum BIOS 1.2
2x1Gb Crucial Ballistix DDR2-1000 5-5-5-15
BFG GeForce 7600GT  Video
Thermaltake Toughpower 650W
WD Raptor 36G - NonRaid Boot
Raid 0 150GB - WD SATA2 + Seagate Barracuda SATA2
Windows XP Professional SP2
COOLER MASTER Mystique 631 Case
  • T9246ED
  • Administrator
what about this one?
AMD GPU Clock Tool: This Overclocking and Monitoring Tool from AMD lets you manage clocks of all their cards including their yet unreleased R600 Series. You can also monitor temperature of the Radeon HD 2000 cards.
http://www.techpowerup.com/downloads/536/AMD_GPU_Clock_Tool_v0.7.html
AaronTopic starter
  • GENERAL
  • BOOST!
Ahh the AMD tool. Heard of it, but never seen it until now.
Shall be adding that BK :)
  • T9246ED
  • Administrator
this one i found it very usefull as well: http://www.thesycon.de/deu/latency_check.shtml
its a not OC related, its diagnostic one but can be very usefull.
AaronTopic starter
  • GENERAL
  • BOOST!
Added that BK. :biggthumbsup:
AaronTopic starter
  • GENERAL
  • BOOST!
UPDATE: *Fix +Addition -Removal /Modification
* Fixed VGA card picture links.
* Underlining not showing on Stability Testing.
/ GFX to VGA for better refrence to forum layout.
+ OCZ SPD-Z tool. IN BETA TESTING. USE AT YOUR OWN RISK!!
  • T9246ED
  • Administrator
here is the Thaiphoon Burner then:
http://cbid.amdclub.ru/files/thphn32.zip
AaronTopic starter
  • GENERAL
  • BOOST!
* Broken links for A64Tweaker and A64MemFreq
  • T9246ED
  • Administrator
here is 2 more usefull applications:
nVHardPage SE v3.6 build 6 beta 1: http://www.nvhardpage.com/files/nvhpse6_b1.exe
Changes:
- added support for new GeForce 8300/8400/8500/8600 series
- added support for new 1xx.xx WinXP drivers
- improved GeForce 8800 support
- improved GeForce Go series support
- updated performance wizzard
- some others small fixes and changes
NVTray:
http://nvtweak.laptopvideo2go.com/
  • T9246ED
  • Administrator
Update Rivatuner as well, version v2.03 of RivaTuner just has been released.
The new RivaTuner v2.03 adds support for ForceWare 162.18, 162.22, 162.50, 163.16 and 163.44 as well as ATI's Catalyst 7.7 and 7.8 drivers.
http://downloads.guru3d.com/download.php?det=163
  • T9246ED
  • Administrator
  • T9246ED
  • Administrator
This one looks very usefull as well:
Open GL FurRenderingBenchmark --> http://www.techpowerup.com/downloads/715/Open_GL_FurRenderingBenchmark.html
Its become very popular. We can make our bench database  :yes:
AaronTopic starter
  • GENERAL
  • BOOST!
+ Disclaimer (thought this is very important)  :yes:
+ Open GL FurRenderingBenchmark
+ RivaTuner Vista x64 Driver
+ Info pages for some apps
+ wPrime stress testing app
/ Changed "All The Overclockung Utilities You Could Ever Need" to "OCUBA - Overclocking Utilities and Benchmarking Applications"
And other general improvements (spelling errors etc.)
All links have been checked - all functioning.
Also just whipped up a little logo.
  • T9246ED
  • Administrator
Re: OCUBA - Overclocking Utilities and Benchmarking Applications
« Reply #36 on: 01-September-07, 08:23:36 »
Well done AaronYuri  :hat tip:
AaronTopic starter
  • GENERAL
  • BOOST!
« Reply #37 on: 02-September-07, 00:11:02 »
+ Info links for almost all applications
+ ATI Tray Tools
/ Few of the download links to more reliable sites
More spelling errors.
P.S God this is hard work...
Quadrifoglio Verde
  • MAJOR
« Reply #38 on: 02-September-07, 06:21:04 »
For Intel, stress testing/stability testing:
Intel Thermal Analysis Tool (TAT)
Not suited for Core 2 Duo temp monitoring, as it is designed for Pentium M processors without an integrated heat spreader. The integrated load test however is one of the best there is, use it to find out your processors maximum temp at certain settings. You will need to use Speedfan or CoreTemp to monitor correct temps. Temps will be higher than those generated by Prime95/Orthos.
Addition for RMclock:
Excellent tool for underclocking, not just overclocking. You can save some serious power by finding the minimum voltage for a certain frequency, therefore your CPU can run cooler and more quiet. Combinations of underclocking when idle and overclocking under load are possible as well.
Desktop
HTPC
  • T9246ED
  • Administrator
« Reply #39 on: 05-September-07, 14:23:12 »
The newest released:
CPU-Z 1.41: http://www.cpuid.com/download/cpu-z-141.zip
    *  New CPU voltage monitoring.
    * Intel Xeon Tigerton support.
    * Intel IA64 CPUs support (Itanium / Itanium2).
      Special thanks to Rami Radi and Ray Hinchliffe for their help.
    * AMD K10 Phenom preliminary support.
    * NVIDIA MCP73 support.
    * Intel XMP profiles support.
    * Memory modules nominal voltage.
NVIDIA BIOS Editor v3.5 :
Changes in this Version
    * Added Support for GeForce 8400 GS PCI-E
    * Added Support for GeForce 7300 GE PCI-E
    * Added Support for GeForce 7200 GS PCI-E
    * Added Support for GeForce 7950 GT AGP
    * Updated Vendor ID
http://www.mvktech.net/content/view/3764/1/
  • 微星科技
« Reply #40 on: 05-September-07, 14:51:13 »
Ah great, Nibitor v3.5! Was about time for 3.4a to get replaced.
Thx for posting it BK!
Windows 10 Pro
MSI MAG BUNKER Case
  • T9246ED
  • Administrator
« Reply #41 on: 05-September-07, 23:52:28 »
Yeah its really a great one :biggthumbsup:
  • T9246ED
  • Administrator
  • T9246ED
  • Administrator
AaronTopic starter
  • GENERAL
  • BOOST!
« Reply #44 on: 28-September-07, 12:14:16 »
+ NiBiTor (download and info)
+ CPU-Z 1.41
  • T9246ED
  • Administrator
« Reply #45 on: 04-October-07, 22:21:45 »
Main Features
    * Support NVIDIA and ATI cards
    * Displays adapter, GPU and display information
    * Displays overclock, default clocks and 3D clocks (if available)
    * Validation of results
    * No installation required
    * Support for Windows 2000 / XP / Vista (both 32 and 64 bit versions are supported)
GPU-Z Validated link: http://www.techpowerup.com/gpuz/wdzwf/
More info and download: http://www.techpowerup.com/gpuz/
  • 微星科技
« Reply #46 on: 05-October-07, 03:08:14 »
Nice! Too bad another validation to be added to sig  and only 25 characters remaining... ;-))
Windows 10 Pro
MSI MAG BUNKER Case
AaronTopic starter
  • GENERAL
  • BOOST!
« Reply #47 on: 06-October-07, 03:39:22 »
+ GPU-Z (Thanks to BOSSKILLER)
Very, very nice app. I'm impressed. :yes:
But I'm using a HD2400Pro ATM, due to RMA'ing X1950. So I'll wait till I get my 2900XT to validate. ;D
AaronTopic starter
  • GENERAL
  • BOOST!
« Reply #48 on: 11-October-07, 06:06:11 »
Release notes:
    * Added Update Checker
    * Improved Shader Detection for ATI cards
    * Added support for future ATI GPUs
    * Various other improvements to detection code
Download
Kafkacell
  • MSIHQ Red Rockets Team Member - Sig King
  • MAJOR
  • Netherlands Antilles
« Reply #49 on: 12-October-07, 10:09:40 »
Works fine with my x1950Pro  :biggthumbsup:
Main rig:
 Laptop: Dell Inspiron 1564 15.6" running windows 7 Home Premium 64bits
Core i3
6 GB DDR3
500 GB Hybrid HDD
The opinions expressed above do not represent those of Micro-Star International or any of their affiliates.
Pages: [1] 2 3  All   Go Up
